Quick price question
Old Nov 28, 2005 | 02:35 PM
alacard's Avatar
Default Quick price question
im working on getting a turbo setup in my 98 dx.
my friends selling a used t3/t4...and he wants me to offer a price.
i dont know the specs on it, and i dont know the condition...but im assuming its good...what should i offer?
ps...i dont know too much about getting a turbo setup together...but im assuming if i buy the turbo first...i can work everything else around that.
Old Nov 28, 2005 | 03:13 PM
bnut510's Avatar
Default Re: Quick price question (alacard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alacard &raquo;</TD></TR><TR><TD CLASS="quote">im working on getting a turbo setup in my 98 dx.
ps...i dont know too much about getting a turbo setup together...but im assuming if i buy the turbo first...i can work everything else around that.</TD></TR></TABLE>
hes your boy... offer him $20.00
Old Nov 28, 2005 | 03:28 PM
alacard's Avatar
haha...i actually simplified it...my friend's brother had it...and sold it to his friend...who isnt going to use it.so its a friend's brother's friend..haha...
but come on guys, any help?
Old Nov 28, 2005 | 03:45 PM
KeyserSoze's Avatar
Default Re: (alacard)
First get the specs, then post them. Also, find out how long it was used check shaft play on it (you know, side to side and in and out, called axial and radial) and post the results as well. I'm sure that with that info someone will give you a guesstimate price of what you should offer. GL.
btw - your nick, I think you fat fingered it when you were typing it......Alucard.
Unless of course you are of some unique ethnicity and it's spelled correctly, if that's the case, my bad, I'm a dumbass.
Old Nov 28, 2005 | 04:35 PM
alacard's Avatar
Default Re: (KeyserSoze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KeyserSoze &raquo;</TD></TR><TR><TD CLASS="quote">First get the specs, then post them. Also, find out how long it was used check shaft play on it (you know, side to side and in and out, called axial and radial) and post the results as well. I'm sure that with that info someone will give you a guesstimate price of what you should offer. GL.
Unless of course you are of some unique ethnicity and it's spelled correctly, if that's the case, my bad, I'm a dumbass.</TD></TR></TABLE>
k, ill try and find that stuff out...even though im not quite sure what shaft play is...but ill try to figure it out.hah.
and no...i get that all the time...my name isn't intended to be "dracula" backwards...it doesn't have anything to do with that.
Old Nov 28, 2005 | 06:25 PM
KeyserSoze's Avatar
10-4 on the name.
Shaft play is where you grab the nut on the compressor and lightly push it back and forth to see if it moves a lot. The right way to do it is to use a dial indicator and see exactly how much play it has then compare that play to the manufacturers specs for the turbo. If the the play is to large then the turbo will have to be rebuilt. The play comes from the bearings inside the turbo wearing out. If there is a lot of wear there will be a greater of play when you move the shaft side to side and in and out. Side to side is referred to as radial play and in and out play is referred to as axial play (I might be backwards on these two, but I think that's right). I believe the side to side play is due to the clearances of the journal bearings (in your case, because the turbo is not ball bearing, most likely not ball bearing anyway) and the in and out play is due to the clearances of the thrust bearings. GL.
This is all from my meager understanding of turbos, so it is by far not the law.
DeeC2
Jan 30, 2013 11:59 PM
boots89
Feb 23, 2010 08:49 AM
Dee A Nine
Apr 3, 2005 12:34 PM
GSRMilanRed
Dec 17, 2003 11:12 PM
