What brand of Headgasket for boosted GSR
I blew my headgasket and need to replace it. Has anyone tried some different brands of gaskets besides oem? Any advantages to certain brands or thicker gaskets for boosted applications? Thanks!
Motor: stock GSR
Motor: stock GSR
Re: What brand of Headgasket for boosted GSR (Tooned)
if your going to change the gasket you should get a set of arp studs and use an oem gasket...
if you want to lower your comrpesion to run a little more boost safely you can get a cometic thicker one
Re: What brand of Headgasket for boosted GSR (D@nnY)
I planned on getting new head studs but I figured with have the head machined that it would be best to run a thicker headgasket. Any one in paticular from cometic
Re: What brand of Headgasket for boosted GSR (JDMSi92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMSi92 »</TD></TR><TR><TD CLASS="quote">I blew my headgasket and need to replace it. Has anyone tried some different brands of gaskets besides oem? Any advantages to certain brands or thicker gaskets for boosted applications? Thanks!
Motor: stock GSR</TD></TR></TABLE>
oem for me... whatever you choose, get arp bolts!
Re: What brand of Headgasket for boosted GSR (FredoSP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FredoSP »</TD></TR><TR><TD CLASS="quote">OEM w/ copper spray and ARP's</TD></TR></TABLE>
Best way to go!
Best way to go!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMSi92 »</TD></TR><TR><TD CLASS="quote">what is the copper spray some of you listed? </TD></TR></TABLE>
"PERMATEX®
Copper SPRAY-A-GASKET® Hi Temp Adhesive Sealant
Fast drying, metallic copper sealant helps dissipate heat, prevents gasket burnout and improves heat transfer. Fills minor surface irregularities. Seals instantly. Fills hot spots and surface imperfections. Temperature range -50°F to 500°F; resists all types of automotive fluids, especially gasoline. ZZP recommended for MLS head gaskets."
"PERMATEX®
Moderator
Re: What brand of Headgasket for boosted GSR (JDM_Risa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Risa »</TD></TR><TR><TD CLASS="quote">OEM . +AEBs head stud=satification</TD></TR></TABLE>
^^^ I use the same combination on my GS-R Turbo
blackccoupe
08-27-2008 08:52 PM
