VARIOUS OIL PICKUPS
Old Nov 26, 2005 | 09:18 AM
xsi-t's Avatar
Default VARIOUS OIL PICKUPS
In my dilema of learning the hard way. i thought it would be best to make this thread to help out others. i went from a b16 to a b18c block and found out that some parts are not interchangeable and this is a key one hop it helps the next guy out.
notice the gsr one is shorter and you need this one do to the block gridle.
Old Nov 26, 2005 | 09:23 AM
BoostedCivicSedan's Avatar
Default Re: VARIOUS OIL PICKUPS (xsi-t)
Werd
Old Nov 26, 2005 | 09:28 AM
TurboCoop's Avatar
Default Re: VARIOUS OIL PICKUPS (BoostedCivicSedan)
are B18B1 and B18C1 oil pans different? cause I dont remember if I got a GSR oil pan when I had to buy a new one, and my block is a B18B1... Its been fine for like 6 months, I just always thought the oil pickups were the same too.
Old Nov 26, 2005 | 09:30 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: VARIOUS OIL PICKUPS (TurboCoop)
the gsr pan is an inch deeper in the shallow end for the windage tray, other than that i think they are the same
Old Nov 26, 2005 | 10:32 AM
xsi-t's Avatar
Default Re: VARIOUS OIL PICKUPS (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">the gsr pan is an inch deeper in the shallow end for the windage tray, other than that i think they are the same</TD></TR></TABLE>
See this is something i didnt know aswell
Old Nov 26, 2005 | 11:16 AM
vaporboy12's Avatar
can you use a ls pick up with a gsr pan. i wanted redo my return flange but the only pan i have laying around is a gsr
Old Nov 26, 2005 | 02:55 PM
xsi-t's Avatar
if im not wrong you have to use the same pan and pickup
Old Nov 26, 2005 | 03:08 PM
asubennett's Avatar
Default Re: (xsi-t)
This is correct.
Old Nov 26, 2005 | 03:40 PM
m R g S r's Avatar
arent ls and b16 oil pans the same? and pickups...?
because from the pic the legs of the b16 and b18b oil pickups look slightly different.....
Old Nov 26, 2005 | 03:50 PM
xsi-t's Avatar
no look at where the oil gets picked up from. They are different. all these pick ups were removed from the blocks to make this thread.
Old Nov 27, 2005 | 08:22 AM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default Re: VARIOUS OIL PICKUPS (vaporboy12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaporboy12 &raquo;</TD></TR><TR><TD CLASS="quote">can you use a ls pick up with a gsr pan. i wanted redo my return flange but the only pan i have laying around is a gsr </TD></TR></TABLE>
yes you can. i've personally ran p72 pans on ls/b20 blocks numerous times with no problems.
Old Nov 27, 2005 | 08:29 AM
quickda6's Avatar
Default Re: VARIOUS OIL PICKUPS (not so civic)
nice post X, we are constantly having to expletive around with different pan/pickup combos
Old Nov 27, 2005 | 12:33 PM
xsi-t's Avatar
Thanks josh im just trying to help all us out when i can
Old Nov 27, 2005 | 04:02 PM
714phil's Avatar
The GSR pans are taller because of the the block girdle. B16's and B18a/b,b20 dont have girdles.. thats why the pans are shorter.
sabele
Feb 6, 2009 06:27 PM
ShortbusEK
Apr 20, 2008 12:00 PM
LBR92DA-T
Dec 20, 2003 02:23 AM
57one
Aug 27, 2002 08:17 AM
