Tial 38mm WG spring question!
Old Jul 8, 2008 | 10:35 PM
ctownintegra's Avatar
Default Tial 38mm WG spring question!
I thought I had a 7.5psi spring in my wastegate, however the car boosts 10psi all day.
I do not have a boost controller and it is running only from the connection on the intercooler piping.
I am going to road race the car slightly under a month from now and want to run 5psi. Do I order a 5 psi spring or a 3.75 psi spring?
Also how hard is it to replace? Is it easy as a BOV spring?
Old Jul 8, 2008 | 10:57 PM
ralph11sec's Avatar
just to be safe, you can order 3.75psi spring and run off a bc to raise it up.
yeah its easy. just be carefull it will kick right back at ya removing a 7.5 spring.
installing the spring is harder. u might need a buddy to help u press the spring
Old Jul 8, 2008 | 11:02 PM
FastEg6's Avatar
Yeah, I would also go with a 3.75psi spring, however that doesn't mean you'll be running that. That'll be just the lowest you will be able to boost, If you can I would just go with a boost controller. If not then go with a lower spring and see if it'll help.
Old Jul 8, 2008 | 11:41 PM
CRXdan's Avatar
Default Re: Tial 38mm WG spring question! (ctownintegra)
I have the opposite problem, 8 psi with a 10 psi spring.
Old Jul 8, 2008 | 11:48 PM
A.E Motoring's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ctownintegra &raquo;</TD></TR><TR><TD CLASS="quote">I thought I had a 7.5psi spring in my wastegate, however the car boosts 10psi all day.
Also how hard is it to replace? Is it easy as a BOV spring?</TD></TR></TABLE>
sounds like your getting boost spike
Old Jul 9, 2008 | 12:16 AM
FastEg6's Avatar
Default Re: Tial 38mm WG spring question! (CRXdan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXdan &raquo;</TD></TR><TR><TD CLASS="quote">I have the opposite problem, 8 psi with a 10 psi spring.</TD></TR></TABLE>
Check your gauge, it may be off. It shouldn't be boosting any lower than your wastegate spring.
Old Jul 9, 2008 | 02:41 AM
ralph11sec's Avatar
Default Re: Tial 38mm WG spring question! (FastEg6)
or just inaccurate spring rate.
Pumpking.
Nov 2, 2016 09:35 AM
ntoxicatedtigah
Apr 26, 2009 01:24 PM
tagperformance
Jun 29, 2007 03:33 PM
9deuce9rr
Mar 28, 2004 12:32 PM
Short Round
Nov 12, 2003 10:16 PM
