compression test
Old Jul 4, 2008 | 08:57 AM
avotegra's Avatar
Default compression test
did a compression test....left to right dizzy.60psi.150psi.150psi.150psi...timing belt...is it ok.......................did the oil drop test was the same............
Old Jul 4, 2008 | 09:05 AM
hotrod99's Avatar
Default Re: compression test (avotegra)
thats not good...60psi is really low and 150 is kinda low too...what compression pistons are you running?,most likely your going to need to rebuild the bottom end
Old Jul 4, 2008 | 09:39 AM
inspyral's Avatar
If you retested with oil the numbers stayed the same, it looks like a problem with your valves/seats on the #1 cyl.
Old Jul 4, 2008 | 09:40 AM
B20luda's Avatar
Default Re: (inspyral)
takes more than a "drop" of oil, use about a teaspoon or so....
Old Jul 4, 2008 | 01:37 PM
TunerToys's Avatar
What happened that caused you to run the test in the first place? Overboost? Overheat? Does it smoke out the exhaust? Blue Smoke, White Smoke?
If it was an overheat, it's probably just a lifted head, bad gasket. Maybe warped head at the worst. Have a machine shop true it up and then put it back together. New water pump and timing belt while you are there.
I agree that 150 is maybe not the highest numbers a Honda will produce, but it's not bad if thats a high mileage engine or low CR pistons, in fact its reasonable.
Doing the oil test will help you separate a ring sealing issue from a gasket, head, valve sealing issue. You need to do them with the engine at a similar temp for both tests, dry and wet.
Hope that helps,
Craig
__________________________________________________ __________________
See our posts in the Sponsor For Sale section for deals on...
GARRETT Turbochargers!
HASPORT Motor Swap Products
SEIBON Carbon Fiber
PRECISION TURBO
Widebands / Conversion Harnesses / 3Bar Maps
SEIBON Carbon Fiber
TURBOXS
ewilliams1990
Jun 28, 2014 03:44 AM
cryingsuns
Jul 28, 2013 10:21 AM
JDMtype Eg6
Jul 14, 2007 02:31 AM
H.A.R.T B18C1EG6
Jul 10, 2006 08:22 AM
dutchman5
Aug 5, 2004 02:58 PM
