KPA to PSI conversion table / chart Accuracy ??
Old Jun 26, 2008 | 12:50 PM
DaveF's Avatar
Default KPA to PSI conversion table / chart Accuracy ??
here is a KPA to PSI conversion table or chart
does anyone know how accurate this is ? thanks
Old Jun 26, 2008 | 12:55 PM
DaveF's Avatar
Default Re: KPA to PSI conversion table / chart Accuracy ?? (DaveF)
why doesnt this thread come up in google search ?
Old Jun 26, 2008 | 12:57 PM
dpetro1's Avatar
i dont think any of that is right, unless those are the numbers above atmosperic pressure. for example 100kpa = 14.5038psi which is just under 1atm (14.70psi)
what is that chart for?
Old Jun 26, 2008 | 12:59 PM
RACEPAK's Avatar
why shouldnt it be?
Old Jun 26, 2008 | 01:04 PM
tony1's Avatar
Looks right to me.
Old Jun 26, 2008 | 01:18 PM
b20beast83's Avatar
Default Re: KPA to PSI conversion table / chart Accuracy ?? (tony1)
i bet the chart is for tire pressure?
Old Jun 26, 2008 | 01:21 PM
DaveF's Avatar
Default Re: KPA to PSI conversion table / chart Accuracy ?? (dpetro1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpetro1 &raquo;</TD></TR><TR><TD CLASS="quote">i dont think any of that is right, unless those are the numbers above atmosperic pressure. for example 100kpa = 14.5038psi which is just under 1atm (14.70psi)
what is that chart for?</TD></TR></TABLE>
the way the engine management system we use reads, it will read 100 kpa with the engine off or 0 vacum
the chart is for reference
Old Jun 26, 2008 | 01:36 PM
turbociv910's Avatar
its right
Old Jun 26, 2008 | 08:54 PM
HiProfile's Avatar
The problem is that he apparently wants it to reference his pressure gauge to the sheet for a car, not strictly absolute pressure reference.
I have to point out the sheet is wrong. On a gauge, 1atm~14.7psi~101kpa. So I think at 300kpa (200kpa above atm), you'd have 29.2psi on the gauge (14.5+14.7psi). At 500kpa (400kpa above atm), I think its 58.2psi. The main issue is using absolute and gauge pressure scales. I think that scale ended up using 14.7psi as 100kpa equiv, not 14.5psi, due to 1 atm being 14.7psi.
I've always hated going using gauge measurements, I prefer absolute. Thats why I sorta like kPa more now.
Old Jun 26, 2008 | 10:50 PM
wHOAlly's Avatar
Default Re: KPA to PSI conversion table / chart Accuracy ?? (HiProfile)
seems a bit off.
101.3kpa=14.7psia/0psig
Old Jun 27, 2008 | 03:09 AM
DaveF's Avatar
Default Re: KPA to PSI conversion table / chart Accuracy ?? (wHOAlly)
its close though, eh ? it seems some of the digits are upping by .8 and some by .7,
when i look for conversion formula's 1psi =6.8948 kpa = 0.06805 atm, using that logic, would mean the conversion table should be off by a good bit ?
google search #3
Old Jun 27, 2008 | 11:21 AM
whiteef8's Avatar
beolingus
good conversion website...use it at work all the time
Old Jun 27, 2008 | 03:49 PM
nowtype's Avatar
100mbar = 10kpa
In google, in the search engine type "X mbar to psi" and it will convert whatever you need. Then just divide by 10. If you need to reference it to a gauge pressure, just subtract it from 101.35kpa. Negative will be vacuum and positive will be positive(obviously).
mrx
Jul 30, 2007 12:39 PM
Turbo_Mike
Jul 18, 2005 09:14 PM
dctoast
Feb 4, 2005 03:55 PM
Boostless97Lude
Jan 10, 2003 12:56 PM
rioninja
Mar 15, 2002 10:09 PM
