turbo identification question!!!
Old Jul 3, 2008 | 08:31 PM
97ekb18b's Avatar
Default turbo identification question!!!
i have a turbo off a 280z from the early 80s it has a t3 exhaust flange, i know it has a .63 ar turbine side but i cannot find out how big the compressor side is, im trying to find a compressor map for it for a tune but dont no what size turbo to go with ive heard its a 60 trim....... IDK please help
Old Jul 3, 2008 | 08:48 PM
97ekb18b's Avatar
Default Re: turbo identification question!!! (97ekb18b)
bump i need to no so i can order my base map tomorrow!!
Old Jul 3, 2008 | 10:09 PM
97ekb18b's Avatar
bump!!!
Old Jul 4, 2008 | 09:14 AM
turbodano's Avatar
That is not a bad turbo I have made 300whp with it before. The compressor flows 505cfm at 14 psi.
Old Jul 4, 2008 | 10:24 AM
TheShodan's Avatar
Moderator
Default Re: turbo identification question!!! (turbodano)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbodano &raquo;</TD></TR><TR><TD CLASS="quote">That is not a bad turbo I have made 300whp with it before. The compressor flows 505cfm at 14 psi.</TD></TR></TABLE>
That's not bad for a small street turbo. That's about 35.5lbs/min@14psi. Think of a small 16G size..
Old Jul 4, 2008 | 10:43 AM
97ekb18b's Avatar
Default Re: turbo identification question!!! (TheShodan)
this turbo is way way bigger than a 16g it has a t3 style flange its off a nissan 280z and is just oil cooled, i can get a picture if anyone needs one...
Old Jul 4, 2008 | 10:56 AM
97ekb18b's Avatar
heres the pictures of it
Old Jul 4, 2008 | 11:10 AM
grand champ's Avatar
Defiantly a t3!!
Old Jul 4, 2008 | 11:47 AM
97ekb18b's Avatar
Default Re: (grand champ)
yep now what size do you think the compressor size is the turbine is .63 whats the compressor side......... i think i might just have them burn me a base map for a 50 trim.......
Old Jul 4, 2008 | 02:46 PM
97ekb18b's Avatar
Default Re: (97ekb18b)
bumpz!!
Old Jul 4, 2008 | 02:57 PM
m R g S r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97ekb18b &raquo;</TD></TR><TR><TD CLASS="quote">yep now what size do you think the compressor size is the turbine is .63 whats the compressor side......... i think i might just have them burn me a base map for a 50 trim.......</TD></TR></TABLE>
You already have the flow rate, why do you need to know the size?
Old Jul 4, 2008 | 08:19 PM
97ekb18b's Avatar
Default Re: (m R g S r)
im guessing its a 50 trim im not sure if it is or not thats why im asking
Old Jul 5, 2008 | 07:46 AM
Optiks.'s Avatar
It's a T3 60 trim comp and .63 a/r if its the one with that weird elbow o2 housing
Old Jul 5, 2008 | 09:39 AM
Rickdrizzle's Avatar
haha that's a pretty big stock turbo.
Old Jul 5, 2008 | 09:58 AM
chimmike's Avatar
Default Re: (Rickdrizzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rickdrizzle &raquo;</TD></TR><TR><TD CLASS="quote">haha that's a pretty big stock turbo.</TD></TR></TABLE>
It was fed by a 3L V6, so for that motor, not really that big haha.
Old Jul 5, 2008 | 10:49 AM
SpoolnG2's Avatar
Default Re: (chimmike)
Who cares what size it is....you shouldnt boost on a base map anyways. Put the turbo on...get it tuned...then see what it does.
Old Jul 5, 2008 | 08:59 PM
94delslo's Avatar
Default Re: (SpoolnG2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnG2 &raquo;</TD></TR><TR><TD CLASS="quote">Who cares what size it is....you shouldnt boost on a base map anyways. Put the turbo on...get it tuned...then see what it does. </TD></TR></TABLE>
fo sho
Old Jul 6, 2008 | 12:02 AM
97ekb18b's Avatar
i wanted teh best base map possible so i need to no if it was a 50 or 60 trim thanks for all the help guys!
Old Jul 6, 2008 | 07:07 AM
SpoolnG2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97ekb18b &raquo;</TD></TR><TR><TD CLASS="quote">i wanted teh best base map possible so i need to no if it was a 50 or 60 trim thanks for all the help guys!</TD></TR></TABLE>
Even the best "base" map you should not boost on. It is unsafe. It makes no difference if its a 50 or 60 trim just like I said above. Dont boost it until its actually tuned and then you'll see what kind of power the turbo makes and such. That will give you a better idea as to what size trim it is.
Old Jul 6, 2008 | 07:45 AM
chimmike's Avatar
Even the best "base" map you should not boost on. It is unsafe. It makes no difference if its a 50 or 60 trim just like I said above. Dont boost it until its actually tuned and then you'll see what kind of power the turbo makes and such. That will give you a better idea as to what size trim it is. </TD></TR></TABLE>
unles you have a wideband that you can monitor closely until it's tuned properly...of course.
Old Jul 6, 2008 | 08:37 AM
SpoolnG2's Avatar
Personally...i still wouldnt do it. But hey, thats just me.
Old Jul 6, 2008 | 02:53 PM
97ekb18b's Avatar
im going to boost it to all hell on the basetune haha JK i was just told to find the right compressor map for the tune so thats all i was doing guys thanks again for the help i go tit all bolted on today the turbo is so big it doesnt even start to spool till 3500 ish lol
blackeg
May 18, 2008 06:20 PM
AspectIndustries
Oct 15, 2007 04:03 PM
hwoody77
May 25, 2005 07:14 AM
yusoslo
Feb 10, 2004 02:55 PM
i3oricua
Feb 21, 2003 07:49 PM
