Down pipe fabrication obstacle
Old Jun 27, 2008 | 11:20 PM
yakuza's Avatar
Default Down pipe fabrication obstacle
About to fabricate 3" down pipe for my Garret T3/T4 57 trim 63a/r turbo but think there might be a problem. The flange is 2.5" and the piping is 3", if I we weld the pipe onto the flange its going to be difficult to fit screws or bolts onto the fitting holes as the pipe is too close to the edges.
Any suggestions or ideas on how to overcome this !!!
Old Jun 27, 2008 | 11:34 PM
Garage 808 Hatch's Avatar
heat the pipe with a torch, and dent it a bit with a ball peenn hammer to clear the bolt heads, then shave the surface flat again
Old Jun 27, 2008 | 11:56 PM
k24em2's Avatar
Default Re: (Garage 808 Hatch)
yep, as said dent the pipe around where the bolts go
Old Jun 28, 2008 | 12:57 AM
yakuza's Avatar
Good idea, thanks guys .. Hopefully I don't ruien ii the process ...
Old Jun 28, 2008 | 04:18 AM
L_J_Scheepers's Avatar
why not use a 2.5" to 3" cone, should give you alot more clearance around the bolts, and will match up perfectly with the outlet flange
96 GSR-T's Avatar
Default Re: (yakuza)
You can also buy Allen Head Bolts so that you dont have to slip a socket of wrench around the bolts, you tighten them from the middle..... that is what I did, I only had to dent one spot to get a bolt in.
Old Jun 28, 2008 | 04:22 AM
96 GSR-T's Avatar
Default Re: (L_J_Scheepers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by L_J_Scheepers &raquo;</TD></TR><TR><TD CLASS="quote">why not use a 2.5" to 3" cone, should give you alot more clearance around the bolts, and will match up perfectly with the outlet flangebending the pipe past 90 deg to get it back under the oil pan...... </TD></TR></TABLE>
If he is using a ramhorn there is no room for a cone increaser, you would have to weld the pipe back past 90 deg just to get under the oil pan if you could fit it past the slave cyl in the first place.
Old Jun 28, 2008 | 06:24 AM
sbiggi's Avatar
Default Re: (96 GSR-T)
Get a 2.5" pipe and have a exhaust shop stretch it to 3". It makes a quick transition in maby less then a half inch.
This is the only pic I have of mine.
Downpipe Picture
Old Jun 28, 2008 | 06:31 AM
Autoworks's Avatar
Default Re: Down pipe fabrication obstacle (yakuza)
Use Allen head bolts and indent it, it'll be fine without a flare/cone. Just be sure you center the pipe on the flange. (you can do it without indenting it as well, but the allen bolts are a must)
Greg
http://www.go-autoworks.com
Old Jun 28, 2008 | 06:37 AM
dartonh22's Avatar
Default Re: (sbiggi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sbiggi &raquo;</TD></TR><TR><TD CLASS="quote">Get a 2.5" pipe and have a exhaust shop stretch it to 3". It makes a quick transition in maby less then a half inch.
Downpipe Picture</TD></TR></TABLE>
thats what i did.
Old Jun 28, 2008 | 07:43 AM
raiden571's Avatar
could weld it on the inside then just tac weld around the outside
Old Jun 28, 2008 | 08:02 AM
95dxsir2's Avatar
Default Re: Down pipe fabrication obstacle (Autoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks &raquo;</TD></TR><TR><TD CLASS="quote">Use Allen head bolts and indent it, it'll be fine without a flare/cone. Just be sure you center the pipe on the flange. (you can do it without indenting it as well, but the allen bolts are a must)</TD></TR></TABLE>
try putting the flange in a vise, put the allen bolts in the flange holes, put the 3" downpipe on the flange, center it and tack.
you can buy the bolta at a hardware store..ie ace,home depot, lowes
Modified by 95dxsir2 at 9:10 AM 6/28/2008
wwolf771177
Dec 31, 2013 08:04 AM
95whitegizzer
Jun 20, 2006 11:27 AM
Teg4e
May 29, 2002 10:41 AM
