Ctr intake cam and GSR exhaust cam ????????????????
i got a built b16a3 turbo car that i put together..421whp on a dyno jet on pumpgas .
.. im running a ctr intake cam and a gsr exhaust........ is it worth it to get the matching ctr exhaust camshaft ? would i see the gains????? i know i would have lil more lag with the ctr exhaust....... but i need some input guys....
Re: Ctr intake cam and GSR exhaust cam ???????????????? (turbociv910)
ctr/itr exhaust cam is NOT the same as a b16a.
OP: What turbing wheel, housing size and type of manifold are you running?
Re: Ctr intake cam and GSR exhaust cam ???????????????? (hybrid_KJ)
why would you have more lag with the CTR exhaust cam? I thought the lift would be higher aiding in the exhaust breathing out faster than the GSR. Good numbers by the way on the B16
If I recall the '01 ITR exhaust cam and the CTR exhaust cam are the same. Someone can verify or correct me on this?
Re: Ctr intake cam and GSR exhaust cam ???????????????? (blaze the chemi)
ctr and itr exhaust cams are the same........... but they only have 1.5mm more lift than the gsr exhaust cam...... i just dont know if $380 is worth a few extra poneys.......
Re: Ctr intake cam and GSR exhaust cam ???????????????? (Shartek)
my turbo is a Borg warner S256 .58 hot side spools as fast as the 3076r they are close turbos but abouve 20psi the borg just pulls away from the 3076r...... the borg starts to run out of breath at 30-35 psi where the 3076r falls off at round 23-24 psi..... that was my deciding factor when i purchased mine......its rated to 550whp so its between the 30r and the 35r....... i would say but spools alot faster than a 35r..... im more than happy with it on my b16
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shartek »</TD></TR><TR><TD CLASS="quote">my turbo is a Borg warner S256 .58 hot side spools as fast as the 3076r they are close turbos but abouve 20psi the borg just pulls away from the 3076r...... the borg starts to run out of breath at 30-35 psi where the 3076r falls off at round 23-24 psi..... that was my deciding factor when i purchased mine......its rated to 550whp so its between the 30r and the 35r....... i would say but spools alot faster than a 35r..... im more than happy with it on my b16</TD></TR></TABLE>
keep the cam setup you have its perfect. what intake manifold are you using, also what turbo manifold.
my s366 spools the same as my 35R does, i would imagine your turbo spools insanely fast
Re: Ctr intake cam and GSR exhaust cam ???????????????? (mrbsponge)
running a skunk 2 pro series intake manifold and a peakboost turbo manifold..... like the ram horn style...... i want to run the s366 next year...... im not worried about lag so much ... 10k rev makes up for it
so you dont think buying the matching ctr/itr exhaust cam would benefit?
lo0nY
01-19-2006 05:31 PM
Combustion Contraption
05-03-2004 02:17 PM
redGSRguy
12-29-2003 06:38 PM
