turbo
Old Jul 5, 2008 | 03:31 PM
avotegra's Avatar
Default turbo
looking for a quick spool turbo capable 450whp....and nice powerband....About the motor i have it build and sleeve so i should be fine...........but all i want is 450 quick spool and nice powerband...want spool around 3000rpm and full boost by about 4000 rpm....................................
Old Jul 5, 2008 | 04:23 PM
hotrod99's Avatar
Default Re: turbo (avotegra)
i would look into the Borg Warner S256
Old Jul 5, 2008 | 09:19 PM
TheShodan's Avatar
Moderator
Default Re: turbo (hotrod99)
THis really depends upon the displacement of the engine that you have. Please be as specific about your build as possible. In most cases, the Borg-Warner S256, STC Silver Surfer, or GT3076R could do all of that under 20psi, but the more information you give to us, the more precise we can be to help.
Old Jul 5, 2008 | 10:40 PM
avotegra's Avatar
Default Re: turbo (TheShodan)
engine built whit stock compression gsr.......82mm..overbore.......with je piston cower rod.........stock rebuild gsr head stock cam.........everything just been rebuild with new gasket........looking to not spend as much as 800 for the turbo.............
w3aselll
May 20, 2010 05:28 PM
dinku27
Sep 12, 2005 05:28 AM
channy
May 13, 2005 06:23 PM
gsrcoupe
Feb 2, 2005 12:58 PM
b18cTurbo
Nov 29, 2001 08:06 AM
