neep help on catch can set up
Old Jul 1, 2008 | 07:26 PM
91daINTEGRAda91's Avatar
Default neep help on catch can set up
i have a built b series in a da integra and i just got it tuned but it smokes out the exhaust undre boost turbo is fine and its not the motor so they said to run a pcv valve so i drillede a hole in my valve cover and installed one the motor is a obd1. i was wondering how to hook up a catch can and if there is anything else i can do to eliminate the burnig oil. pics would be great of the catch can set up. thanks for the help
Old Jul 1, 2008 | 07:36 PM
blinx9900's Avatar
Default Re: neep help on catch can set up (91daINTEGRAda91)
option 1: catchcan- hook up a hose of your valve cover vent to a sealed can, this will catch oil that spills out the valve cover under extreme cornering
option 2: positive crank case ventilation can- get your self a PCV can that has two ports on side, i underneath and 1 filter on top. ports on side both will go to ports on back of block, port underneath the can will Tee into one of those lines from the back of the block to serve as a drain back.
now i believe you actually wanted a PCV can so go with option 2.
Old Jul 2, 2008 | 04:34 AM
boostedcivicsir's Avatar
Mr. Badwrench
covered many times:
https://honda-tech.com/zerothread?id=1199935
search crankcase archived also
yyyktk1
Aug 10, 2014 04:08 PM
jdmfoglights
Jan 8, 2014 09:50 PM
PR8urVtec
Jan 1, 2014 04:58 AM
91daINTEGRAda91
Jul 1, 2008 09:38 PM
potatobiker8
Mar 13, 2007 12:10 PM
