Rough Idle/Bog
Old Jun 24, 2008 | 10:56 AM
LST2's Avatar
Default Rough Idle/Bog
I have run into a problem recently with my idle. The car seems to idle fine for a few seconds, sometimes even 10-20 sec, then I get a quick rich bog and drop in idle RPM, sometimes it even dies. It is not a consistent surge, it is very erratic. It almost seems like there is a loose ground but I checked all of those. I am going to check my battery today as well as I have always had battery issues with my car and it has been a while since I checked it. I was also thinking a vacuum leak but I did not see any and that would cause a constant low/rich problem. I also get a little bog at times even when accelerating/cruising, but not as frequent or noticeable.
Do you guys know of anything else that may cause this?
Old Jun 24, 2008 | 11:44 AM
SovXietday's Avatar
Default Re: Rough Idle/Bog (LST2)
Are you on open or closed loop?
Old Jun 24, 2008 | 11:53 AM
LST2's Avatar
Default Re: Rough Idle/Bog (SovXietday)
I just started runing in closed loop last week. I had the problem when I was in open loop... that is why I switched it to closed. The problem has seemed to get progressivley worse over the last few days.
hardcore97
Apr 12, 2014 02:00 PM
PhatwhipsJDMkits
11
Apr 7, 2009 05:51 PM
ic89
Oct 16, 2006 05:38 PM
bob16ost
Feb 10, 2004 11:41 AM
TheIntegraGuy
Jan 22, 2004 06:48 PM
