Vitaras?
Old Jul 7, 2008 | 04:24 PM
Project_SOHC_EX's Avatar
Default Vitaras?
Does anyone make the Vitara Pistons in a 76mm overbore I would like to see how they do on my D17 turbo project.
Old Jul 7, 2008 | 06:30 PM
hotrod99's Avatar
Default Re: Vitaras? (Project_SOHC_EX)
yes they make 76mm vitara's,but i dont think they make them for a d17...
Old Jul 8, 2008 | 03:04 AM
Semnos's Avatar
Default Re: Vitaras? (hotrod99)
They also don't make them for the D16.
People just use them as is.
You'll have to figure out what comp. ratio it will be in your engine.
Old Jul 8, 2008 | 04:55 AM
Do you know who makes the 76mm vitaras as the second guy stated they're a Suzuki Pistion I know the application is made specifically for Honda's now but originally they're an OEM Suzuki Piston for the Vitara and people used them in their Honda because of the bore size. Catch my drift...anyone?
Old Jul 8, 2008 | 06:19 AM
TunerToys's Avatar
Vitaras are a pretty well established idea in the Honda Forced Induction world. Search the forum for "Vitara" and you should get a decent amount of results.
I am not sure about 76mm Vitaras, but do know that there are 75.5mm versions available.
Also, a user on here (or on HMT) "FJT" is probably going to be your best bet on what is available for Vitara products. I believe he now even offers a custom rod with a longer BE dimension to correct the combustion height in some blocks.
Good luck and post up numbers!
Craig
See our posts in the Sponsor For Sale section for deals on...
GARRETT Turbochargers!
HASPORT Motor Swap Products
SEIBON Carbon Fiber
PRECISION TURBO
Widebands / Conversion Harnesses / 3Bar Maps
SEIBON Carbon Fiber
TURBOXS
Old Jul 8, 2008 | 09:35 AM
welfarepc's Avatar
Nice, tunertoys sending customers to fjdistributors.com.... you know your product is the **** when...
im 99% sure FJT offers 76mm. would be cool to see em in a D17!
Old Jul 8, 2008 | 10:03 AM
grand champ's Avatar
http://fjdistributors.com/prod...d=165
Old Jul 8, 2008 | 10:06 AM
fjt's Avatar
fjt
Hi Guys..
Yes they come in 76mm bore..
The Forged rods we designed are specifically to run the Vtara into the D16 and also the JDM D15 Vtec engines.
I dont know if these rods will work on the D17
Old Jul 8, 2008 | 10:07 AM
fjt's Avatar
fjt
BTW: Thanks Craig..
Old Jul 8, 2008 | 10:45 AM
EJ8 944's Avatar
Default Re: (fjt)
here is a good link for findind compression ratios, vitara's included.
http://www.zealautowerks.com/dseries.html
Old Jul 9, 2008 | 05:37 AM
fjt's Avatar
fjt
And a Rods teaser for you guys.. je je
Old Jul 9, 2008 | 07:39 AM
phatrick2332's Avatar
What makes the vitara's so good for boost on the D16? I have been under the impression that it was just because of the lower CR that they worked well. With the longer rods getting them closer to deck height, and people still making power, that leads me to believe im wrong. Can someone give me some info on these?
Old Jul 9, 2008 | 10:49 AM
welfarepc's Avatar
Default Re: (phatrick2332)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phatrick2332 &raquo;</TD></TR><TR><TD CLASS="quote">What makes the vitara's so good for boost on the D16? I have been under the impression that it was just because of the lower CR that they worked well. With the longer rods getting them closer to deck height, and people still making power, that leads me to believe im wrong. Can someone give me some info on these?</TD></TR></TABLE>
ive been having those same thoughts.... but ive already purchased the rods and pistons, and the block is in the machine shop. so i guess im the guinea pig lol
some of the benefits of the vitara piston are still a large dish for lower comp
additional oiling holes
Teflon coating
Old Jul 10, 2008 | 05:12 AM
TunerToys's Avatar
Default Re: (fjt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fjt &raquo;</TD></TR><TR><TD CLASS="quote">BTW: Thanks Craig..</TD></TR></TABLE>
You are welcome! Thanks for selling quality parts with excellent customer service over the years.
FJT =
Craig
__________________________________________________ __________________
[See our posts in the Sponsor For Sale section for deals on...
SEIBON Carbon Fiber
PRECISION TURBO
SEIBON Carbon Fiber
TURBOXS
Old Jan 26, 2010 | 05:36 PM
lt1guy's Avatar
Icon3 Re: Vitaras?
i just bought those rods and there is no oiling hole by the main bolt like the stock rods how will the piston and cylinder wall stay cool
Old Jan 27, 2010 | 10:00 AM
2.0L_of_fun's Avatar
the cast is diffrent from honda too, the are "semi forged" if we can sa that. stock sleve plus custom rod+vitara pistons from fjt is able to take up to 400whp "safely"
unknown0001
Jun 3, 2007 10:14 AM
christiantequila
Honda Civic (2001 - 2005)
11
Jun 2, 2007 03:00 PM
Toddz Grafixxx
36
Jan 14, 2007 01:01 PM
PreStaged12s
Jul 17, 2006 05:26 PM
