cel when boostin for a couple of seconds?
i get cel when boostin for a couple of seconds in third gear, my gauge shows only 5psi at the most, i even haave a missing link on my map sensor. isnt the stock map sensor suppose to handle even 10 - 12 psi of boost?
ill be getting a chipped ecu in a couple of weeks but just want to know what is up with this. might even have the same problem with the chipped ecu will i?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4dek »</TD></TR><TR><TD CLASS="quote">i get cel when boostin for a couple of seconds in third gear, my
ill be getting a chipped ecu in a couple of weeks but just want to know what is up with this. might even have the same problem with the chipped ecu will i? </TD></TR></TABLE>
is the missing link installed correctly?
the stock map can handle 11.2 IF THE ECU CAN INTERPRET THE POSITIVE PRESSURE.
silverbulletgsr
May 20, 2004 08:24 AM
