Need advise for a Head Gasket in a Turbo d16a6.
Old 07-05-2008, 09:14 AM
Jwbetley's Avatar
Default Need advise for a Head Gasket in a Turbo d16a6.
Hi,
I have a d16a6, TT H-beams, 75.5mm vitaras and a .42/.48 50ish trim turbo. The block was decked and the head was resurfaced. I decided to use the stock head gasket which is not metal; it's composite. The head gasket blew and I'd like to purchase a metal one.
I would like some advice on what to get. Would it be worth it to get an OEM 3-layer metal HG and If so, what car/engine is compatible with a d16a6? I am also thinking about using a cosmetic HG, maybe thinner (.027, .030) to raise my compression up a bit. Not sure if it is worth it though. Please comment.
Please point me i the right direction. Thanks
-Justin
P.S. Am I a complete idiot for running a composite HG on a turbo engine? When researching, I noticed that everyone swore by OEM hg's with FI. I just didn't realize that the OEM Hg's being used with success were metal and not composite.
Old 07-05-2008, 07:05 PM
CRXdan's Avatar
Default Re: Need advise for a Head Gasket in a Turbo d16a6. (Jwbetley)
Just use any OEM or aftermarket replacment MLS head gasket for a 92-95 civic si d16z6. I have a beckarnley or w/e in mine and no issues. (made in japan)
and yes composite HG's suck on boosted motors. it pays to do research. drink a 6 pack and read honda-tech for 3 hours, itll save you money
Old 07-05-2008, 08:18 PM
TunerToys's Avatar
We ran the Z6 MLS gasket in our A6/Y8/Vitara/MiniMe project CRX, and had no problems until we overheated it. I'd caution against a composite head gasket, and suggest that you use ARP head studs when you pt it back together.
IMHO, a MLS Honda gasket will perform just as well as a Cometic, for this application and thickness.
Also, if you are running the A6 head, I'd stick with the factory gasket, or go a bit thicker to lower compression a bit. Just depends on how good of a tune you have on it. If you are running a Z6 or Y8 head, a thinner gasket is in order, depending on how much you decked it.
Hope that helps, and thanks for purchasing a set of our rods!
Craig
__________________________________________________ __________________
See our posts in the Sponsor For Sale section for deals on...
GARRETT Turbochargers!
HASPORT Motor Swap Products
SEIBON Carbon Fiber
PRECISION TURBO
Widebands / Conversion Harnesses / 3Bar Maps
SEIBON Carbon Fiber
TURBOXS
Old 07-05-2008, 08:23 PM
CRXdan's Avatar
not to threadjack but i too, have purchased your rods. thumbs up for offering an excellent product at a very competetive price!
Old 07-06-2008, 07:22 AM
Jwbetley's Avatar
Default Re: (CRXdan)
Thanks. So, a d16z6 OEM MLS gasket should work on a d16a6 wuth the stock a6 head? Do I need to get a 75.5mm head gasket or will the oem 75mm work? Im pretty sure it will but I'm asking to be safe. I am already running arp head studs. Thanks a ton; I'm excited to get my wagon running again.
Old 07-06-2008, 12:22 PM
97grnrs's Avatar
ive run the composite hg on every single cam i built.. and thats alot , with no problems... just use arp studs if its blowing its cause of other reasons most likely.
Old 07-06-2008, 02:39 PM
Jwbetley's Avatar
Default Re: Need advise for a Head Gasket in a Turbo d16a6. (97grnrs)
resurfaced head and decked block. I am using ARP's and torqued them down correctly. I am only leaking coolant through the cylinders. The composite HG was form a gasket set and I don't feel that it's a quality Honda OEM part. I am hoping that the problem is only the head gasket. Cracked sleeve would really suck.
Old 11-21-2014, 02:32 PM
luis253's Avatar
bump to a six year old post!
what is the OEM thickness of a D16A6 Head Gasket?
I have resurfaced the head a couple times and had the block decked, so looking to compensate for the machine work with a thicker gasket.
and what were some web site that have custom thickness?
More Information for DNJ ENGINE COMPONENTS HS290
Old 11-21-2014, 04:55 PM
Moderator in Chief
Muckman's Avatar
This will tell you the head gasket thickness - Honda D-Series Compression Calculator by ZealAutowerks
And Cometic makes thicker MLS head gaskets.
Old 11-21-2014, 11:12 PM
TravisBiggie's Avatar
why would you spend extra money on a thicker headgasket? buy one on ebay for like 22$, MLS gasket only. Used one on my 500whp eg, and been using them on the multiple motors I've built without issue. Yeah it bumps up the compression with a milled head n decked block, but it doesn't hurt... if anything... its improve your MPG and power.
Old 11-22-2014, 06:12 AM
Moderator in Chief
Muckman's Avatar
Why? A little thing called piston to head and piston to valve clearance. Just because you were fine doesn't mean everyone else is fine. You should measure to be sure.
Old 11-23-2014, 01:03 PM
Tippyman's Avatar
Been using a Napa Z6 headgasket for about 6 years now. Hasn't blown yet! (And with proper tuning it shouldn't.)
Old 11-24-2014, 06:59 PM
luis253's Avatar
HAHA^ dude knows what i am saying, have the head machined a couple times and the block decked once, need a little compensation for the missing metal!
why a thicker headgasket? #WEEKENDWARRIOR!
Old 11-24-2014, 07:00 PM
luis253's Avatar
Sounds like you have been gasket stacking!
Old 07-01-2022, 09:56 AM
Dick Rounds's Avatar
Default Need advise for a Head Gasket in a d16a6. Vitra Build .005 the head, and .004 block
So just gt my first engine together with a vitra set up looking for head gasket info d16a6 on my 91si deck @.004. And bored .020 then resurfaced head @ .005 so how thick do I need n what is the HG.
Old 07-01-2022, 11:00 AM
highschooler's Avatar
Default Re: Need advise for a Head Gasket in a d16a6. Vitra Build .005 the head, and .004 blo
The Supertech Performance catalog lists the D16A as being a different part number for the head gasket than the D16Y and D16Z6. The Supertech one is 0.033” thick. The only ones I know of thicker than 0.033” are skunk2 and Cometic, but I’ve read about lots of problems with the Cometic. The Skunk2 is listed as a D16Y gasket. I wasn’t able to find any head gaskets in 75.5, only 76mm, which is ok for 75.5.
So that’s some info, but I can’t recommend any of them at this point.
Old 07-02-2022, 05:13 AM
-Intl Steve Krew
Caoboy's Avatar
He’s bored .020” over, .5mm is ~.020”.
Old 07-02-2022, 08:42 AM
I couldn’t find any head gaskets 75.5mm, only over an extra .5 at 76mm, but I was told the 76mm gasket works fine on the 75.5mm bore ( .020” over).
Old 07-02-2022, 08:51 AM
O.G. triple O.G.
NVturbo's Avatar
stock size.... 75mm headgasket will work. Have that on my setup.
Jokerchris
03-21-2015 01:42 PM
Joeski99Si
04-23-2009 05:24 AM
Joeski99Si
04-22-2009 09:57 PM
Lmgrcivic
02-06-2005 04:55 PM
Slimm-rw-
11-28-2004 09:45 AM
Quick Reply: Need advise for a Head Gasket in a Turbo d16a6.
