WTF?? What causes this?? Broken throwout bearing which came with my CC stag4 4 clutch
1 Post
WTF?? What causes this?? Broken throw out bearing which came with my CC stage 4 clutch
Yesterday I removed y tranny cause I´ve had probems to shift into gears. This is what I found:
I´ve driven this flywheel/clutch combo aprox 3k miles. Its a competition clutch stage 4 clutch. Engine is a stock B16 with EG6 gearbox and quaife LSD. No more mods.
Modified by hovic at 3:35 PM 6/28/2008
1 Post
Re: WTF?? What causes this?? Broken throwout bearing which came with my CC stage 4 clutch (SpoolnG2)
cause I switched from a cable to a hydro tranny and I´ll boost my engine in a few month.
Re: WTF?? What causes this?? Broken throwout bearing which came with my CC stage 4 clutch (hovic)
i had the exact same problem with my clutchmaster stage 2, and i mean exact. never found a cause. through a new one in been good for 5,000 plus miles so far. i would double check your fork and make sure its not bent and lube your input shaft to ease the bearing movement.
1 Post
Re: WTF?? What causes this?? Broken throwout bearing which came with my CC stage 4 clutch (postman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by postman »</TD></TR><TR><TD CLASS="quote">i had the exact same problem with my clutchmaster stage 2, and i mean exact. never found a cause. through a new one in been good for 5,000 plus miles so far. i would double check your fork and make sure its not bent and lube your input shaft to ease the bearing movement.</TD></TR></TABLE>
did you switch to a OEM bearing?
yes, i used an oem. my honest thoughts were just a bad bearing possibly when releasing the clutch and the fork slamming back away from the clutch was just to much pressure for the hold tabs. if it help im an ASE certified technician and i came up ith no visible problems to cause this.
1 Post
mh.. no reply from competition clutches or my dealer I got the clutch from
I used an OEM bearing on mine and no problems yet. The CC one didnt fit in my cable a6 tranny anywas.
No idea why that happened but there is alot of pressure being put on that bearing maybe CC uses a cheap one. I woudl only use OEM though.
hovic
06-28-2008 08:25 PM
