DSM Injector help...
Old Jun 27, 2008 | 01:07 AM
sepetinswenze's Avatar
Default DSM Injector help...
I am installing my DSM 450 injectors into my 1999 Integra GSR, B18c2 engine... I need to know if i must use a resistor box??? i was told yes by one person then no by another. I tried searching, but nothing about it for my engine... Thanks in advance
Old Jun 27, 2008 | 05:47 PM
grndcont's Avatar
yes you do. there is a Gray electric plug on the drivers side of the eng compartment with yellow/black stripes wires (i think). it wont be plugged into anything, it will just have a cap on it. i don't remember much else about it, but i pretty much just plugged my (salvage yard) Honda resistor box into it and changed out the injector plugs for obd1's. there's more to it than that, but that's all i can remember. hope it helps.
Old Jun 27, 2008 | 05:56 PM
Robert Padron's Avatar
Default Re: (grndcont)
you could also solice the black/yellow wires and solder in a 10watt 10ohm inline resistor and call it a dam. Cover it with some plastic wire loom so it looks clean. Worked for me.
Old Jun 28, 2008 | 04:10 AM
Default Re: (Robert Padron)
Where do i get these resistors? i have an old resistor box from a Mitsubishi, will this work?? thanks
Old Jun 28, 2008 | 04:24 AM
all_motorsi's Avatar
Default Re: (sepetinswenze)
only BLUE TOP DSM's need a resistor box. I use Black top's without and they run GREAT
Old Jun 28, 2008 | 07:23 AM
grndcont's Avatar
check e-bay for 90's civic (obd-0) resistor box. or, if you can wait until oct i'm selling my matched (rceng) dsm 450's + my resistor box. also, have you looked at just getting saturated injectors? would be easer for just a little more $.
Modified by grndcont at 9:30 AM 6/28/2008
Old Jun 28, 2008 | 07:29 AM
grndcont's Avatar
dude, this took like 15 seconds on google to find: http://www.team-integra.net/fo...Topic
http://flightquote2.hypermart....x.jpg
http://hondaswap.com/parts-sal...30570/
i know the post is old, and the box is no longer for sale, but that is excatly what you need.
092eg6
Feb 11, 2010 09:00 PM
markgo
Nov 8, 2006 11:39 AM
yodas-gsr
Oct 24, 2005 01:41 AM
Licensed2Spool
Apr 12, 2003 10:51 AM
