sohc ~ dsm blue vs black top 450cc injectors
ive searched and could not find a solid answer.
i am boosting a d16y8 from a 98 civic and i have a couple questions about the dsm injectors.
since the blue's are obd1 and single spray, and the blacks are obd2 and dual spray, should i be getting the black ones since my car is obd2a?
another thing is ive been hearing alot about running resistors for the injectors, early hondas wont need them but the later ones do, (or something like that)? will i need to use resistors for my civic?
thanks all
thanks all
1 Post
Re: sohc ~ dsm blue vs black top 450cc injectors (jrivehard)
yes you need resistors or more preferable is a resistor box or injector driver, it doesnt matter what injectors you use black or blue tops, just the black tops have a dual hole in the pintle cap, I dont think its any advantage. the blue and the black tops also both have the same connectors so obd should not play a role
one mroe thing crxjimmy, i was reading this thread: https://honda-tech.com/zerothread?id=2331406
and allmotorsi said "only BLUE TOP DSM's need a resistor box. I use Black top's without and they run GREAT "
will i still need the resistor box if i were to buy black tops? or is it just misinformation
drjondurst
01-29-2019 09:47 AM
