Boost difference for GT30 to GT35 upgrade?
Old Jun 26, 2008 | 09:26 AM
purpleh22's Avatar
Default Boost difference for GT30 to GT35 upgrade?
I'm running a GT30 on a built H22. I'd like to get the same power with lower boost pressure and also be able to develop more hp if I decide to.
I currently develop around 435 whp @ around 17 psi using E85, with the GT30. Would I be likely to get the the same whp @ 15 psi or so, with the GT35?
Old Jun 26, 2008 | 10:21 AM
jaydim's Avatar
it could be posible since its a 2.2, i have a gt35r on 84X87 gsr and made 460 on 17psi, are you planing on making more power if not just keep the gt30r
Old Jun 26, 2008 | 02:57 PM
SpoolnG2's Avatar
Default Re: (jaydim)
Yes, thats what should happen. You should make more hp on a lower psi due to the turbo flowing a higher lb/hr at the same psi versus the smaller turbo. If your looking into the GT35r, I would also take a look at the BW T3 S362ett.
Old Jun 26, 2008 | 05:13 PM
purpleh22's Avatar
Default Re: (SpoolnG2)
Thanks, that's my understanding. I want to make around 500 whp.
With 1000cc injectors and E85, I'm already using E85 instead of methanol/H2O in my methanol injection system for added capacity. Guess I'll be using 1600cc injectors so I can eliminate the additional E85 injection.
ohsnapzafingcu
Dec 17, 2012 04:08 AM
sparda2024
Aug 22, 2012 12:16 PM
27psi
Dec 23, 2009 04:15 AM
Rocks
Jun 18, 2004 02:15 PM
austrian type-R
Sep 26, 2001 08:00 PM
