Arp head stud installation
Old Jun 30, 2008 | 08:50 PM
cbustuner's Avatar
Default Arp head stud installation
Quick easy question,I've noticed some guys recomend that you re-torque the head studs after a few heat cycles,Are you just loosening all the studs and then re-tightening them to spec or what? How many guys actually use this process?
Only reason I ask because I have always been told anytime you loosen or untorque the studs the gasket needs to be changed or it may not seal right,and I don't want to mess anything up.
Old Jun 30, 2008 | 08:52 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Arp head stud installation (cbustuner)
no..
let the car heat up and cool off a bit, then just make sure they are torqued as they should be, dont loosen them
Old Jun 30, 2008 | 09:10 PM
cbustuner's Avatar
Default Re: Arp head stud installation (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">no..
let the car heat up and cool off a bit, then just make sure they are torqued as they should be, dont loosen them</TD></TR></TABLE>
That's exactly what I did, and none of them needed anything.I just wanted to make sure I was understanding it right.
Old Jun 30, 2008 | 09:29 PM
wantboost's Avatar
Who is Mr Robot?
yea, then you're good to go
projectef
Nov 7, 2008 12:15 PM
Tuner Eddy
Feb 18, 2008 09:23 PM
freddysEF
May 23, 2007 01:26 PM
rdeezy78
Apr 18, 2007 09:06 PM
Dyno Queen
Aug 11, 2003 04:45 PM
