turbo b16 problem...???
Old Jun 27, 2008 | 01:08 PM
h22_bb4's Avatar
Default turbo b16 problem...???
hi
i have EG with b16 and revhard stage 3 turbo kit and it includes 990cc injectos (low impedance), when i started the engine the fuel was rich and the engine does not stay on even when i instal the stock injectors the problem still the same???
note:-
the fuel pump is aeromotive
AEM fuel rail
do i have to put resistnce box to work this injectors ????
could the problem be electrical messing or what ????
could the ground be the problem if its not connected well???
PLZ help asap because I want to start that car........
Old Jun 27, 2008 | 01:48 PM
KevronsEG's Avatar
Default Re: turbo b16 problem...??? (h22_bb4)
I think you do need a resister box.
What ECU/ fuel system are you running?
Old Jun 27, 2008 | 02:02 PM
ketchup!'s Avatar
Default Re: turbo b16 problem...??? (KevronsEG)
low impendence injectors require a resistance box
Old Jun 28, 2008 | 12:44 AM
h22_bb4's Avatar
I'm using AEM EMS but I try to start it and it not starting but when I use the stock computer it starts but the fuel is too rich????
Old Jun 28, 2008 | 09:54 AM
hotrod99's Avatar
Default Re: (h22_bb4)
is this car dyno tuned?
Old Jun 28, 2008 | 12:23 PM
SD_Lurker's Avatar
HT White Ops
Yes, low impedance injectors, peak and hold, require a resistor box. Saturated injectors do not need a box.
Old Jun 28, 2008 | 12:35 PM
h22_bb4's Avatar
hotrod99.. no still not tuned we just want to start it first and see if there is any messing or leaking...
and the problem is that we dont have AEM tuner here in UAE so we will see about the tunnig after we start the car....
Old Jul 1, 2008 | 02:41 PM
h22_bb4's Avatar
any one ?????
Old Jul 1, 2008 | 02:49 PM
95dc2teg's Avatar
you need a basemap for you specific set-up so you can run those injectors...
Old Jul 2, 2008 | 02:02 AM
h22_bb4's Avatar
where can i get the basemap???
Old Jul 2, 2008 | 04:53 AM
hotrod99's Avatar
J-K-tuning.com or Phearable.net
Old Jul 2, 2008 | 08:28 AM
daddycivic's Avatar
Go to aem site. There forum should have a base map you can down load. You might want to down load the latest software.
cticknor666
Jul 29, 2009 01:39 PM
h22_bb4
Jul 24, 2008 04:53 AM
projsectEF
Jun 11, 2006 06:13 PM
Lenne
Oct 27, 2005 05:31 PM
redcivicek
Jan 12, 2004 09:39 AM
