chipped ecu need aftermarket map sensor?
im planing to buy a chipped p28, will i need a 2bar, 3bar map sensor or i can use my stock one? im only be boostin around 8-10 psi. and oh do you have any recomendations where to buy chipped p28 with basemaps?
if you have a stock engine that can handle a given power out put, and say will die at 12 psi. if you run a stock map sensor, it can only see 11.2 psi. so if cut is set for 12 psi, the ecu will never see 12 psi, and engine carnage will result.
if you plan on running 10 psi on a 11.2 psi map sensor, you may creepa little to 11 psi and have a hiccup from boost cut being that high.
get a 3 bar, you may not now go to 28 psi, but you can in the future, and your boost cut will work properly.
boost cut is a safeguard if the turbo gets out of control. to not grenade the engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">if you have a stock engine that can handle a given power out put, and say will die at 12 psi. if you run a stock map sensor, it can only see 11.2 psi. so if cut is set for 12 psi, the ecu will never see 12 psi, and engine carnage will result.
boost cut is a safeguard if the turbo gets out of control. to not grenade the engine.</TD></TR></TABLE>
Well said.
Craig
__________________________________________________ ___________________
See our posts in the Sponsor For Sale section for deals on...
GARRETT Turbochargers!
HASPORT Motor Swap Products
SEIBON Carbon Fiber
PRECISION TURBO
Widebands / Conversion Harnesses / 3Bar Maps
SEIBON Carbon Fiber
TURBOXS
Well said.
Craig
SEIBON Carbon Fiber
PRECISION TURBO
SEIBON Carbon Fiber
TURBOXS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4dek »</TD></TR><TR><TD CLASS="quote">so a boost cut is like a wastegate?</TD></TR></TABLE>
No, a wastegate is an actual part on the car.
Boost cut is a software feature that allows your engine management system to not allow your vehicle to exceed x psi read by the map sensor...
the.hamburglar
Aug 2, 2007 02:44 PM
