sohc setup sound good?
official honda whore
well i blew up my d16z6 in my 93 si hatch and i am in the process of putting together another motor, i have an old motor from my 95 dx sittin around and i was gonna do a mini-me swap with it, i plan on running a greddy kit at like 6-8 psi and i was wondering a couple of things?
is an intercooler def important?
by running colder plugs what does this mean, i will be buying plugs for it this week and i want to know (sounds stupid but id like to know)
i will be puttin a d16z6 head on that 1.5 block, will the compression be too high for boost? if not how many pounds could it handle stock with a d16y8 headgasket
what trainy should i use, the dx trainy or an si trainy?
what clutch would you all recommend?
what all do you recommend for engine management, i am new to the FI forum and would appreciate all and any help
The intercooler helps you run more boost. You run colder plugs if its a daily driven car for sure... With the D16y8 on a stock head gasket you can push around 12 psi. of boost. If you do the fuel and timming right. You will have to deal with the MAP sensor. Go with a ACT at least a stage 3. Get a Hondata if you have the cash.
Good Luck!!!!!!
Good Luck!!!!!!
well what would be good fuel management, there are no dynos around here, so what would be the best bet, i might do a homemade turbo, or try to get a greddy one??? would injectors off a b17 work, or atleast be any better, at most right now i plan to run 8 pounds
[Modified by coptzer, 12:25 AM 2/4/2003]
Eg2707
12
Dec 22, 2006 03:21 PM
