How to lower boost on a t25
Old Feb 1, 2003 | 08:48 AM
bottledcrx's Avatar
Default How to lower boost on a t25
I'm currently putting a t25 on my zc and from what i read they boost over 6psi and i cannot find anything in here on how to lower the boost.... Any help would be great.....
Old Feb 1, 2003 | 08:52 AM
98AccordEX's Avatar
Default Re: How to lower boost on a t25 (bottledcrx)
does it have an internal wastegate? i think most T25's do. you cant go any lower than what the spring is set to on the wastegate. you can only go higher. why do you wanna go lower than 6lbs anyway?
i'm from Harrisburg. not too far from York. hit me up on a PM
Old Feb 1, 2003 | 08:57 AM
lowexr's Avatar
open the WG and cut the spring....my 14B is set at 3PSI now....make sure the WG is well seal after...
Old Feb 1, 2003 | 09:24 AM
bottledcrx's Avatar
Default Re: How to lower boost on a t25 (98AccordEX)
I want to lower the boost... I heard that they boost somewhere around 10psi . I guess i'll figure something out
Old Feb 1, 2003 | 02:19 PM
bottledcrx's Avatar
Anyone
Old Feb 1, 2003 | 06:54 PM
chirish's Avatar
Buy a new actuator with a softer spring pressure. I believe the T25's off of an Eclipse have around a 9-10psi actuator spring rate, so you can contact Turbonetics or Garrett and they should offer a softer spring or even a new actuator.
Old Feb 1, 2003 | 09:26 PM
T25 civic's Avatar
Default Re: How to lower boost on a t25 (PssshhhMr2)
TEC in golden colorado has them. I got one for my t25 and its a 4 psi spring. I'm running 6 psi right now. 75 dollars shipped overnight. Very good customer service and great prices. It does require slight modifications. You have to reuse the flange and the arm from the old actuator. You have to cut the old canister off the flange, drill holes, bolt the new canister on and weld the actuator arm onto the short arm comming out of the canister. Very easy and very nice.
Nick
Old Feb 1, 2003 | 11:23 PM
Full-Race Javier's Avatar
my garrett T25 has an internal gate with an actuator at 7psi. heres the part # of the actuator if u want it.
Old Feb 2, 2003 | 12:39 PM
bottledcrx's Avatar
Default Re: How to lower boost on a t25 (javierb14)
Thanks.. I'll have to cross that over to mine and see what i come up with..
98.4DR.EK.D16
Sep 3, 2012 03:59 PM
powerdbygarrett
Jul 3, 2008 01:50 PM
cherroneballs
Mar 23, 2006 02:10 AM
zojirushi
Jan 23, 2002 04:42 PM
teg90rs
Dec 6, 2001 03:48 PM
