Building a boosted accord ...
Old Feb 3, 2003 | 07:31 AM
sparknblaze's Avatar
Default Building a boosted accord ...
I am working towards a boosted 95 accord f22b sohc and I "heard" that 8lbs is the most I can run with stock internals. I have found a couple of turbo's on sale but they were used. The T3 (used) by garrett and a T3/T04 (new) by Garrett. I plan to boost it stock first and want to know which turbo to go with before I start changing rods, pistons, valves and springs. I'm piecing my kit together since I think it will be cheaper. The sellers claim there is minor "shaft play". What does this mean?
Old Feb 3, 2003 | 08:09 AM
SI_DRIVR's Avatar
Default Re: Building a boosted accord ... (sparknblaze)
that might mean you need to get it rebuilt. about $300 for rebuilding cause your going to have to send it to a turbo rebuild shop. They need to high speed balance the shaft and change seals, bearings, possible turbine replacement. You might just want to buy new.
Old Feb 3, 2003 | 10:59 AM
Default Re: Building a boosted accord ... (SI_DRIVR)
So if I went for the new t3/t04 would that be good for a small amount of boost 8-10lbs of boost?
Old Feb 3, 2003 | 04:56 PM
poid's Avatar
Should be, i plan on using a GT25 to deliver up to around 11psi on a stock F22B1.
With good tunign and fuel delivery 8-10lbs of boost shouldn't be a problem
Old Feb 3, 2003 | 06:50 PM
PUREVIL's Avatar
Default Re: Building a boosted accord ... (poid)
If i where you i would go all new...
get a kit..
I peiced mine that i use to have together.. I ended up spending more then i thought and it would have been worth buyin new..
I will know for next time i guess..
just my $.02
jofe4
Dec 16, 2011 07:17 AM
RedTT
Mar 27, 2007 01:52 PM
TheBobFather
May 31, 2005 03:06 PM
VisualAutoMotoring
Apr 3, 2003 06:40 PM
Dramier
Jan 4, 2003 06:24 AM
