help on nitrous
Old Feb 3, 2003 | 05:46 PM
hybridlsvtec's Avatar
Default help on nitrous
hey i really need help with my nitrous kit. i put it on and put a 255 bbk fuel pump in and when i turn the bottle on it bogs down and fuel pressure goes down and then it will kick back up. i have fuel set at 45-50 with vacum off. i have stock injectors. well if someone can plz help. thanks
Old Feb 3, 2003 | 05:56 PM
turbodsmpower's Avatar
Default Re: help on nitrous (hybridlsvtec)
just sell the car man
Old Feb 3, 2003 | 06:18 PM
sweet's Avatar
Default Re: help on nitrous (turbodsmpower)
yeah you could just sell the car, or you could give us some details to help you.
what kind of kit, dry or wet/DP?
are you sure the pump is good and installed correctly?
i'll assume this is a wet system since you got the 255 pump. when you inject the fuel psi may drop for a second as the pump supplies fuel to the solenoid and the fuel rail, this is possible. the fuel psi you have should be fine for the N2O system.
also when i bogs down, is it really bad?
if so then you're running too much fuel. when my N2O solenoid acted up and wouldn't open completely or at all, the motor would still inject the fuel portion and bog like crazy because there wasn't any oxygen to go with it.
SiR831
Aug 14, 2005 05:05 AM
TSACIVICSIK20A
Dec 2, 2003 07:21 PM
little red crx
Sep 14, 2002 02:41 AM
