Intake cam?!?
Old Jan 31, 2003 | 08:58 PM
Evil EG's Avatar
Default Intake cam?!?
Ok im putting the motor back together and I put the Cam gear on the exhaust cam and when the bolt got tight it would start turning the cam. Now I start on the intake cam, I put the cam gear on start tighting the bolt but the cam gear never moves....so I put the timming belt on and the crank is at TDC and the cam gears are lined up correctly, so I take a rachet and turn the cranck but the intake cam moved a half of turn the stopped!?!? Then the belt just started slipping. Any Ideas?
Old Jan 31, 2003 | 09:51 PM
Smashback's Avatar
Default Re: Intake cam?!? (BVM)
did you put cam lube on that baby? try taking the caps off and then re-torquing them.
Old Jan 31, 2003 | 09:54 PM
Evil EG's Avatar
Default Re: Intake cam?!? (Hatchblack)
yes i did lube it..yea im gunna take the caps off tomarrow. Would to much torque prevent them from turning?
Old Jan 31, 2003 | 11:12 PM
boosted hybrid's Avatar
This happens a decent amount to me when assembling my engines. You need to loosen everything up, move the cam around in the journals, re-position it then torque down in sequence. For some reason the cams seem that they are seated correctly, and something binds. I just do what i stated above and try again, usually it works by the second time around.
Old Jan 31, 2003 | 11:32 PM
V-SPEC 1's Avatar
Default Re: Intake cam?!? (boosted hybrid)
Old Feb 1, 2003 | 12:09 AM
Evil EG's Avatar
Thanks im gunna try that in the morning tomarrow. That might be it too cause when I installed it I was sitting in a akward position so I just bolted it down into place thinking it would seat from that.
Ill post the out come tomarrow.
Old Feb 1, 2003 | 10:44 AM
Evil EG's Avatar
That was the problem. I just took the cam out then readjusted it and put it back together and now it works like a charm! All I need is my manifold back from the welder and ill have my car back after three LONG months!
riceball777
36
Feb 7, 2006 11:22 AM
integmester
Apr 18, 2005 12:34 PM
rough_draft
Mar 26, 2005 05:32 PM
Mr.Integra
Apr 10, 2003 01:39 PM
Luserkid
Mar 27, 2003 09:03 AM
