Main relay question.. Please help. stuck here.
Old Feb 3, 2003 | 07:53 AM
DIY_Racing's Avatar
Default Main relay question.. Please help. stuck here.
Ok, when the main relay ***** out on a car... When you try and start it does the car just go CLICK, or does it turn over and not start???
Please all help is appreciated.
Old Feb 3, 2003 | 08:08 AM
dasher's Avatar
Default Re: Main relay question.. Please help. stuck here. (DIY_Racing)
Main Relay???? Be more specific... Ignition Relay? What type of clicking... clicking from the relay(doubt u could here that unless you have it up to your ear) or clicking from the starter which is incapable of turning the car over .....
Old Feb 3, 2003 | 08:17 AM
DIY_Racing's Avatar
Default Re: Main relay question.. Please help. stuck here. (dasher)
Ok, if you knew anything about a honda or acura, YOUD HAVE to know what a MAIN relay is..
So what i want to know is if the main relay is bad, will the car turn over but not start, or will the car just go CLICK when your trying to start it.. it wont turn over.
Old Feb 3, 2003 | 08:39 AM
BorderM3's Avatar
If the main relay is 'clicking' good chacne the relay is working.
Obtain a schematic of the relay and give it voltage accordingly to test it(listen for a click when applying volt and ground to the right places).
I have a schematic for a 88-91 crx if you need it.
Old Feb 3, 2003 | 08:50 AM
BudaKai's Avatar
Default Re: Main relay question.. Please help. stuck here. (BorderM3)
Charge your battery please, and then come back with your cocky attitude.
Old Feb 3, 2003 | 08:56 AM
DIY_Racing's Avatar
Default Re: Main relay question.. Please help. stuck here. (tzsir)
charge my battery??? Cocky attitude??
First, i apologize to DASHER if i came across as cocky.
Secondly, kiss my ***. I dont have a cocky attitude. AND THE CAR TURNS OVER JUST FINE. it will not start... WHat the HELL does that have to do with the battery. Just cause your a troll here doesnt mean you know everything.
I just want to know if a main relay is bad will the car turn OVER, or will the car just go CLICK..... NOT THE RELAY CLICKING, i mean the car... like click if the battery was dead..
My car turns over.. it just wont start.. It goes NANANNANANANANNANANA... like trying to start the car with the ecu fuse out.. It just turns and turns.... SO, if the main relay is crap willl the car still turn over and over like that, or will the car just go CLICK, like you have a dead battery.
Old Feb 3, 2003 | 10:10 AM
93LSivic's Avatar
Symptoms of a main relay going bad:
Car doesnt start after is has been running. Or is hard to get started at all. Usually occurs on warmer summertime days--but, if its a bad relay then its a bad relay.
When you turn the key to "on" you dont hear the fuel pump prime.
Apparently a solder joint goes bad in the relay itself...ive heard of people repairing them themselves, but its easier for peace of mind to spend the $56 and buy one from honda.
Old Feb 3, 2003 | 10:33 AM
BorderM3's Avatar
I got like 3 for a 88-91 crx if ya need one
Old Feb 3, 2003 | 01:31 PM
dasher's Avatar
No prob....
I just thought you were a little vague with your question the first time....
you mean the PGM-FI main relay right? Is the clicking coming from your PGM-FI relay or the engine bay.... You want to perform a continuity test on the relay to test it if you suspect a problem ... Section 11 - 111 , 112, 113 of the helms if you have a 3rd gen teg..
kinda hard to help you to much if you don't even let anyone know what kind of car you drive.... ///
Old Feb 3, 2003 | 01:57 PM
BudaKai's Avatar
Well gee if it took my encouragement for you to fully explain yourself then it was worth it. I don't think I'm a troll though, but I'm sure many here would agree. Feel free to have your own opinions. I don't care.
Old Feb 3, 2003 | 02:38 PM
dasher's Avatar
just trying to help someone during my 15 min break at work ... didn't have time to sit around and Immediately respond..... but thanks tzsir; your encouragement on this board is always wonderful...
[Modified by dasher, 6:41 PM 2/3/2003]
Old Feb 3, 2003 | 02:43 PM
BudaKai's Avatar
I get frustrated easily, and I know if I can have something to relieve it on I can think a lttle more clearly. Year's of drug abuse I guess.
I already PM'ed him explaining I wasn't serious I was just trying to get it out of him so we know what the hell he was talking about. Sorry if I offended him, or anyone else.
Old Feb 3, 2003 | 02:50 PM
dasher's Avatar
Old Feb 3, 2003 | 04:05 PM
BigD+Itsuki's Avatar
Default Re: Main relay question.. Please help. stuck here. (93LSivic)
bingo ... I had a bad main relay. Well i still do but now its winter and hasn't affected the cars starting. Good Luck!
Old Feb 3, 2003 | 06:42 PM
Quick 200k Mile Motor's Avatar
Default Re: Main relay question.. Please help. stuck here. (BigD+Itsuki)
If you hear your fuel pump, then most likely the main relay is good.
I say most likely, because the main relay actually has 2 relays in it.
One activates the other. When the 1st one activates, it supplies power to the ECU, injectors, and power to the 2nd relay. The 2nd relay supplies power to the fuel pump. So, most likely the whole relay unit is good if you hear the fuel pump.
Old Feb 3, 2003 | 07:08 PM
IMALLSLO's Avatar
Default Re: Main relay question.. Please help. stuck here. (Quick 200k Mile Motor)
Finally a decent answer after all the sword fighting. If the car doesnt crank..check the starter or the battery. A bad relay will still crank but you wont get any fuel, ignition blah blah etc.....
Old Feb 18, 2003 | 12:56 PM
TurboTeG4's Avatar
Default Re: Main relay question.. Please help. stuck here. (proclassracer)
i changed my relay and still no power
Old Feb 23, 2003 | 10:48 PM
Turbocivic94's Avatar
I can use schematic for 88-91 crx
I might need one, my car wont start, just did OBD1 conversion, I think I fried the main relay. Let me know
Thanx
[Modified by 25 PSI CRX, 7:52 AM 2/24/2003]
SIR EF9
Mar 26, 2009 09:49 PM
lsvtechatch92
Mar 21, 2009 07:47 AM
ninjarich2
May 11, 2007 12:51 AM
91d15bvtec
Jun 27, 2005 06:35 PM
91d15bvtec
Jun 27, 2005 06:15 PM
