who else hates downpipe bolts?
Smarter than you
please leave all v-band comments at home. i WILL do a v-band when i upgrade later.
for now, ive used stainless steel downpipe bolts, lock washers and blue loctite to hold them in. AND its holding them in great. TOO great. i need to take them off, and i cannot break them loose.
i can get the 4 easy ones, but the bottem one thats a bitch to get to, u know which one, WILL NOT break loose. tried WD40, then PB blaster, and a good sized wrench to get torque to it. but nothing, the motor literally torques w/ the wrench when i pull on it. yes i am goin counter clockwise
its not stripped, yet. what should I try next?
Smarter than you
Re: who else hates downpipe bolts? (Arturbo)
i need a torch, and im scared. cause on the can of the pb blaster, it says it is flammable above 120 degrees.
light my car on fire yo!
or
try something else first?
or
Re: who else hates downpipe bolts? (turbocoupe)
Bigger cheater bar?
used the "raise/lower" bar for my floor jack, fits perfectly on my craftsment medium sized wrench
good luck!
Re: who else hates downpipe bolts? (stick)
PB will just smoke and burn a little, depending on how much is on the bolt. Nothing to worry about unless you throw the whole can into a fire.....ha ha!!
Re: who else hates downpipe bolts? (1320development)
I would also like to add the bigger muscle part
OR
Go all out on that mother ****** and have a ride to the hospital once you bust an internal organ
OR
Re: who else hates downpipe bolts? (DIRep)
Re: who else hates downpipe bolts? (Farnsrocket)
I gotta know what a Mexican speed wrench is!
LOL, tell me more about this. I may need one, or can I rent one from you felix..lol
Re: who else hates downpipe bolts? (espanol)
two words, " use studs " lol
btw about the mexican wrench, this also apply to a chinese guy with a degree in ghetto engineering LOl
Smarter than you
Re: who else hates downpipe bolts? (Flamenco-T)
look at u guys, jacking my thread.
i need to find a pipe to use as a breaker bar. only a 13mm wrench, no sockets, will reach this bolt, so its tuff to get a breaker bar on it.
tmw im gonna find some butane, and try torching it. well see what happens. im just really scared of stripping it cause stainless steel strips easily. i guess if i strip it ill just have to buy a little tiny cutter wheel and cut that bitch off. id rather not though. hehe
[Modified by DIRep, 9:35 PM 2/2/2003]
HT's Biggest Loser
Re: who else hates downpipe bolts? (sporkcrx)
wtf is a v-band? Do the v-bands help me with this hatred?
You know I always used anti-seize on mine, no washers or lockwashers, and they never came loost but were easy to take out.
Re: who else hates downpipe bolts? (Hatchblack)
After I put my Hondata IM gasket in, I used the original IM studs that I removed(replaced with longer ones) and put them on my turbine. They're the same thread, 8x1.25 I think, whatever thread DP bolts and IM/EM nuts/bolts are. I just used some new EM nuts and tightened them down, and they don't go anyway, but I can still get them off easilly. They're a lot easier to get on, and make it wayy easier to line the DP up.
I used some hex head bolts on the downpipe to make it easier to get them on and off. It's tough enough fitting a long enough wrench down there to get any leverage on it. After a few thousand miles they started backing out so i said screw it and replaced the bolts with some studs.
