losing boost between gears.
Old Feb 2, 2003 | 08:22 PM
ineedhelp's Avatar
Default losing boost between gears.
the setup is a 2000 gsr with a drag turbo kit. recently ive been experienceing loss of boost when i shift between gears. it just happened out of no where. heres what it does:
i give it full throttle and i get full boost (8psi) at about 4k like normal all the way to redline. but when i shft the boost would drop to about 5psi. and it slowlys rises but barely reaches 8 psi by redline in that gear.
this also happens when i down shift...it would reach 8psi quckly and stays there but when i shift it does the same thing and drops to about 5 psi.
it doesnt matter what gear i start the initial boost at...i lose boost when i shift.
this just happened rescenlty..and i dont know what the cause is because i didnt mess with anything. i checked everything i could and everything seems normal. i assumed it was my blow off valve letting too much out but i checked and it wasnt loose or anythng. by the way i have an hks ssq blow off valve that came with the kit. any suggestion on what it might be?
Old Feb 2, 2003 | 08:41 PM
ineedhelp's Avatar
Default Re: losing boost between gears. (ineedhelp)
anything, anyone?
S2KP
Jul 28, 2004 06:36 AM
djnikko
Aug 14, 2003 03:55 AM
1fstcorrado
Jul 30, 2003 03:17 AM
TurbodCX
May 22, 2002 03:01 PM
92HB_HB
Mar 10, 2002 06:32 PM
