b18b vs b18a
Old Jan 31, 2003 | 07:01 AM
BorderM3's Avatar
Default b18b vs b18a
is the b18b a stronger bottom end stock?
Old Jan 31, 2003 | 09:01 AM
BorderM3's Avatar
Default Re: b18b vs b18a (BorderM3)
common this is a easy one... for you B series guys
Old Jan 31, 2003 | 09:47 AM
blufke's Avatar
yes it is. the b18b comes with iron ductile sleeves and a block guard stock, the 18 is deceiving too because its actually a 84.5mm bore as opposed to the 74.745mm bore of the b18a(also deceiving). you can boost up to 3 BAR with good tuning on a stock b18b. or, you could search.
but ummm. they are the same.
Old Jan 31, 2003 | 11:44 AM
BorderM3's Avatar
Default Re: b18b vs b18a (blufke)
so therefore the B18a has longer rods to achieve the same displacement?
Furthermore, if i do a performance build on a B18 it isnt of much benefit to go with a b18b??? I have a 90 integra coming in I am going to strip...this is why i am asking.
Thanks
Old Jan 31, 2003 | 11:50 AM
DIRep972's Avatar
Smarter than you
oh my. that was mean.
the blocks are the same internally. externally there are a few differences, for instance the b18a has a different drivers side motor mount then the B18b.
[Modified by DIRep, 12:51 PM 1/31/2003]
Old Jan 31, 2003 | 11:55 AM
BorderM3's Avatar
Default Re: b18b vs b18a (DIRep)
This guy rambled all that bullshit just to **** with me to tell me to search...
I can appreciate it that, much more creative than the normal bullshit you hear... ******* SEARCH "NEWB"
Old Jan 31, 2003 | 01:03 PM
avividmemory's Avatar
DIRep is right, internally...they are more/less the same, few external differences...the head is where the real difference in the two is at...
Old Jan 31, 2003 | 01:17 PM
blufke's Avatar
yeah, people did it to me when i was fairly new, so it is my duty to do it to you. they are the same though. boost happy motors(to a point). but you really can find alot about most of your Qs in the archives(generally not too much will show up under recent).
Old Jan 31, 2003 | 01:20 PM
dustin's Avatar
The block is internally the same. I don't know why honda even bothered to change the engine code.
Old Feb 1, 2003 | 01:35 AM
Jdm_Rice_Monster's Avatar
Default Re: b18b vs b18a (dustin)
yeah arent the heads a bit different or is the intake manifold. Doesnt the ecu that comes in the 92 up make the hp difference.
Old Feb 1, 2003 | 02:02 AM
Armed Ferret's Avatar
Default Re: b18b vs b18a (JdmRiceMonster)
90-91 (130 hp rated) have different cams than 92-93 (140 hp rated) b18a's. the b18b head is slightly different and the cams are a bit better yet. but if you're planning on building anyway, the b18a is your best bet; you can get them on http://www.car-part.com for under 400 bucks; about half the going rate of a solid b18b.
if you're planning on boosting a stock motor and then building it later (notice i don't offer the option of simply boosting a stock motor and that's it.....there's a reason for this, hint hint. ) b18b would give you better performance right away, and then building it up yields better gains yet.
[Modified by SlowRedTeg, 3:03 AM 2/1/2003]
Old Feb 1, 2003 | 02:08 AM
Full-Race Geoff's Avatar
Default Re: b18b vs b18a (SlowRedTeg)
also the map sensor is on the firewall (not TB), intake mani slightly diff, and the TB is smaller on a b18a. Valve cover different, and also i believe the b18a uses a slightly higher flowing oil pump, gsr pump perhaps? that might be BS tho...
Old Feb 1, 2003 | 02:11 AM
Default Re: b18b vs b18a (FFgeoff)
i had 2 oil pump failures, so if that's true then gsr pumps suck.
edit: lots of people confuse the 92-93 integra (in general) with the 92-93 gsr (b17a).....i'm sure someone of your caliber, jeff, wouldn't do that, but that might be where you're getting the gsr pump thing. $.02
[Modified by SlowRedTeg, 3:12 AM 2/1/2003]
Old Feb 12, 2003 | 01:46 PM
ion_four's Avatar
to hijack a thread from the dead...
what are the differences in the heads of the b18a and b18b? Does the b flow significantly better, or is it just the cams and ECM?
latinf86
Sep 5, 2006 02:04 AM
methodz55
13
Apr 11, 2006 07:15 AM
CRXSleeper
17
Sep 17, 2002 06:42 PM
