5psi on a .48 a/r T3, are stock injectors w/out FMU or FPR okay?
just curious about this. if it would be okay on 87-91 octane etc...
if its okay, i was thinking about waiting to get my 12:1 FMU and DSM injectors when I get my intercooler..
otherwise..i will purchase the FMU and injectors today
thanks again!,
mike
thanks again!,
mike
Re: 5psi on a .48 a/r T3, are stock injectors w/out FMU or FPR okay? (MikeMAN)
If you run stock injectors, you need an FMU...period.
12:1 FMU on stock injectors is common practice.
If you have a way of controlling those 450cc DSM injectors, you will NOT need an FMU. The VAFC hack or SMC+ will do the job just fine.
Sonny
Re: 5psi on a .48 a/r T3, are stock injectors w/out FMU or FPR okay? (Sonny)
Sonny
Sonny
so a 12:1 fmu on stock injectors w/out DSM's would be fine for a non intercooled 5psi setup?
thanks anyways tho turboD hehe..j/k
edit:sp
[Modified by MikeMAN, 5:00 PM 2/1/2003]
Yes, that will work. Keep the boost at 5psi or less until you get better fuel management. You also absolutely MUST have an inline fuel pump or your motor will go boom.
Sonny
Sonny
i was gunna get a Walbro 255lph intank anyways
thanks again sonny,
mike
thanks again sonny,
mike
Save your money and get an SMC+! Way better then any FMU, and cheaper! You really don't need a fuel pump or anything else other then the 450's. Very easy install and works magic . It is amazing the simplicity and size differencr from the safc and smc. Unless you want Bling bling, go smc!
Re: 5psi on a .48 a/r T3, are stock injectors w/out FMU or FPR okay? (CivicSoul)
yea, i was reading about those the other night! no bling bling! just a powerful little tuning tool for sure! and not very expensive at that! i think it was only around $110 or so. Also, since im getting an IC/RC 550's and a hondata in the summer, should I just do ghetto radiator hose (2.5" from like a semi or something you can buy at napa or checker) for my turbo charge piping (well, all the way up to my AEM CAI.
thanks guys!,
mike
thanks guys!,
mike
khmboostedeh2
03-25-2005 11:48 AM
