Running a safe turbo
Old Jan 31, 2003 | 02:13 PM
CBR600OnTop's Avatar
Default Running a safe turbo
Alright I just got a rev hard 2C with all neccasary piping and all. Now I want to get the goodies on top of it to run it safely and more efficent. I am going safc, fuel pressure regulator, and some gauges. Later on I will be putting in turbo timers and boost contollers. Just want enough stuff right now to run it safely. Now I want some of your guys's input on what else I can get to make my turbo the cleanest running. Thanks
PAUL
Old Jan 31, 2003 | 02:25 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: Running a safe turbo (TegTuner)
I would not get a boost controller. It can be the death of your engine, because you going to want to boost past what your suppose to. I would up grade the wastegate to a tail35mm. Bigger injectors and you should be fine. Just don't abuse it.
Old Feb 4, 2003 | 06:33 PM
tegasaurus's Avatar
PAUL
in other words, you're worried about my self funded car beating your... well i use that term lightly... car?
A Turbo timer is a must.
It's all in the tuning paul... spend about a good 1 or 2 hours on a dyno, and your car will run great. Maybe we should dyno ours together... a little group dyno thing
-Ryan
Old Feb 4, 2003 | 06:39 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: Running a safe turbo (tegasaurus)
want it to run safe as possible?? get hondata and save the money on the safc,vtec controller,turbo timer, and excessive gauges. the safest way to turbo a car is to have proper mgmt!!!
Old Feb 4, 2003 | 06:42 PM
ekb18c's Avatar
Default Re: Running a safe turbo (MotorMatrix.com)
That's the best advice I heard all night, I couldn't have said it better.
93supercoupe
Jan 23, 2006 09:43 AM
justinb
Jun 25, 2005 04:40 PM
E46M3CB
Jun 12, 2003 05:08 AM
turbod16y8
Mar 23, 2003 04:44 PM
xci_ed6
Dec 22, 2002 04:49 AM
