blue smoke at idle... what could it be....
New User
Re: blue smoke at idle... what could it be.... (scttydb411)
Is your return line getting backed up? Maybe some oil is backing up into the turbo and spilling out the exhuast?
Guest
Posts: n/a
blue smoke= oil
white smoke=coolant
bad rings???
white smoke=coolant
bad rings???
i'll check the oil return to make sure it isn't backing up....
what about thicker oil, is it possible that the oil is to thin and slipping through the seal on the turbo?
Guest
Posts: n/a
Re: blue smoke at idle... what could it be.... (Boosted97Lude)
Damn sam that thing won't stop leaking oil in one place or another.....why don't you go buy a real car!!! ROFL just kiddin...let me knwo if I can help ya man I'm a few miles out ya know.
It could be valve stem seals or turbo seals.
If it's a new motor, it could be that the rings haven't seated properly yet.
Only way to find out is to do a test.
See if it's the motor or turbo.
