Ever installed your own turbo?
Old Feb 2, 2003 | 04:03 PM
Lewie's Avatar
I'm here for the gangbang!
Default Ever installed your own turbo?
I have a 98 GSR and am going to be turboing it in the next couple of months....What I want to know is whether or not anyone has installed their own turbo and how easy/difficult it is and what I need to know before I start. I can use all the help/suggestions you all have.
Thanks
Old Feb 2, 2003 | 04:04 PM
bartek_b's Avatar
Default Re: Ever installed your own turbo? (lewie4)
check out this link
https://honda-tech.com/zerothread?id=403890
Old Feb 2, 2003 | 04:21 PM
greddyturboGSR's Avatar
Default Re: Ever installed your own turbo? (mugen85r)
Doing your own turbo install isn't bad as long as you make sure you have all your parts on hand along with a couple of friends. My greddy kit took me 3 days to install. I spent one day draining oil, pulling off the the headers and downpipe taking out the fans, etc. And then the next day bolting it all on. And then the last checking fluids and checking for leaks and loose bolts. good luck.
Old Feb 2, 2003 | 04:40 PM
DIRep972's Avatar
Smarter than you
i think most people on this web site pay super humans to install their turbo kits. its not something anyone can do.
just do your research, and don't be scared. you learn alot when u install a turbo kit. my only suggestion is take ur time and don't cut corners. it will pay off over time.
Old Feb 2, 2003 | 04:46 PM
bottlefedb18c1's Avatar
Default Re: Ever installed your own turbo? (DIRep)
me and my freind installed my turbo kit it wasnt that bad other then grinding the block down and drilling and welding the oil pan
it took us 3 days but it was after work so about 2 hours a night and alot of beer but that didnt help out i think
Old Feb 2, 2003 | 04:48 PM
Lewie's Avatar
Default Re: Ever installed your own turbo? (boostfedb18)
what about the gauges....what does it take to install the guages? Has anyone installed their gauges also?
Old Feb 2, 2003 | 04:49 PM
turbocoupe's Avatar
If you can switch out exhaust manifolds, your halfway there...
Old Feb 2, 2003 | 04:51 PM
they are not that bad like the boost gauge goes after the TB of the manifold and the A/R goes off you O2 sensor
bimmerboy
Jan 21, 2008 06:56 PM
gotzrycefoolio
May 29, 2005 07:34 PM
ITRfaithful
Jun 30, 2002 12:37 PM
wantgoback
Apr 1, 2002 05:07 PM
GruvyTune
Oct 20, 2001 05:16 PM
