Rust on Manifold
Old May 7, 2003 | 12:53 PM
TurBoXBirD16's Avatar
Default Rust on Manifold
I have taken off my manifold and turbo
now the manifold has been sitting around, and it's been snowing and raining
then i see some rust on it
should I remove those rust before I put them back in??
if YEs, what should I use?/
WD-40 then sand paper??
thanks
Old May 7, 2003 | 12:55 PM
FIxALPHA's Avatar
Default Re: Rust on Manifold (TurBoXBirD16)
WD-40 and Sandpaper is fine.
Old May 7, 2003 | 01:20 PM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Default Re: Rust on Manifold (FIxALPHA)
Maybe you should get it Jet=Hot coated or somethign while it's off before you put it back on.
s.cha
May 11, 2009 08:44 PM
Blindstuff
Oct 5, 2004 06:33 PM
