welding pipes
Old May 7, 2003 | 04:00 PM
Spudddy's Avatar
Default welding pipes
Hey instead of finding some silicon hoses to connect tubes.. how strong would a mig weld hold up a 2.5" pipe to a 2.25 pipe? boosting max of 10psi
Old May 7, 2003 | 04:10 PM
t04s's Avatar
It would take a helluva lot more than 10psi to break a good MIG weld.Are you saying you just want to jump a 1/8" gap?Why not go to the local muffler shop and have them blow the 2.25 up to 2.5 and wled it up nice?
Old May 7, 2003 | 04:13 PM
Spudddy's Avatar
well i bought a mig welder today and i'm peicing together a charge pipe.. using an AEM CAI for the charge pipe and my hks ssq bov was on a charge pipe off the ic kit that i bought.. the charge pipe from the TB didn't fit soooo i had to go hacking away at it on my own. As long as it wont hurt my 10psi of boosting i wont really care
Old May 7, 2003 | 05:14 PM
93LSivic's Avatar
Default Re: (Spudddy)
Good luck trying to mig aluminum
Old May 7, 2003 | 07:20 PM
johnisenglish's Avatar
Default Re: (93LSivic)
You can MIG weld aluminum using aluminum wire, no problem.
Old May 7, 2003 | 07:22 PM
Spudddy's Avatar
i welded them together, and they are holding, looks hella ugly due to the gap there was.. had to build up a puddle and make a bridge for it i'll post some pics tomarrow.. but i guess i could just throw some thermal wrap over it and hide it had to turn my new 199 home depo welder down to "low" setting high was just eating through the aluminum
Old May 7, 2003 | 07:42 PM
hatchy's Avatar
Default Re: welding pipes (Spudddy)
dont worry about that, but you should worry about little "holes" in your welds that will leak boost.
Old May 7, 2003 | 07:46 PM
Spudddy's Avatar
i've gone over them about 10x already and will be doing it about 5x more times tomarrow making SURE there are no little holes i'm **** about the leaks
Old May 7, 2003 | 07:47 PM
Tinker219's Avatar
dude...cut that whole weld off and clamp the pipes together with some huge hose from Napa. youre just asking for trouble welding aluminum to steel...I didnt even know it was possible
Old May 7, 2003 | 07:49 PM
Spudddy's Avatar
Tinker, get your *** on aim
Old May 7, 2003 | 07:53 PM
B18EG6's Avatar
Default Re: (johnisenglish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnisenglish &raquo;</TD></TR><TR><TD CLASS="quote">You can MIG weld aluminum using aluminum wire, no problem. </TD></TR></TABLE>
you certainly can.... i did it ghetto with a one pound aluminum spool on a ten pound spool thingee.... please check out my thread...
any questions feel free to IM me... thanks.
https://honda-tech.com/zerothread?id=495720
Ash J. Williams
Nov 2, 2013 04:17 PM
TurboSI56
Welding / Fabrication
Jul 12, 2006 01:01 PM
EK FLY
31
Aug 23, 2005 06:50 PM
rice a roni
17
Apr 8, 2005 07:58 AM
