Going for turbo Rebuild Question of CR for Pistons?
Probably gonna be a sleeved b16 block forged everything, How much boost could I handle with 10:1 compression? Or would I be better off dropping it to 9:5 for some saftey?
Re: Going for turbo Rebuild Question of CR for Pistons? (Spooled1.6L)
Whats up Delaware friend
10:1 is fine if you are gonna get it tuned. people go low like 9:1 to be safe when they are running "the hack" or and fmu setup.
Re: Going for turbo Rebuild Question of CR for Pistons? (ricodemus)
oh yea I think I know you guys. I got the Blue Turbo Ek hatch. I hung out with you guys up at painters one night.?
well, I don't actually "roll" with SC tuning, but all the guys there are awesome and thats where I go to get work done.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spooled1.6L »</TD></TR><TR><TD CLASS="quote">Probably gonna be a sleeved b16 block forged everything, How much boost could I handle with 10:1 compression? Or would I be better off dropping it to 9:5 for some saftey?</TD></TR></TABLE>
if you wanna boost a lot, i would drop the CR down to 9.1. if your thinking about keeping the higher compression so you can make more power at lower boost levels, your making your engine do most of the power production. if you drop the CR and boost more, then your making your turbo do more of the power production.
IMO, turning up the boost is a better way of making power than having a higher CR. just get lower CR pistons and up the boost
1 Post
I would say 10:1.
I am set on 10:1. Id rather make the same power at a lower boost level.
Higher comp give faster spool, less intake temp charge since boost isnt as high.
It was hard for me to decide between high and low comp. On low comp, you can run more timing to make the power also and not worry about california 91 octane as much.
Search the archives and there are lots of topics on this.
HT's Biggest Loser
Re: Going for turbo Rebuild Question of CR for Pistons? (ekb18c)
10:1 is good if you rather run less boost with faster spool. you can even go 9.5:1 for a piece of mind if it makes you feel better
Re: Going for turbo Rebuild Question of CR for Pistons? (SIXTYdashONE)
So any guess how much hp/tq id have with a b16 with the 10:1 forged everything good tuning and about 15 psi?
lovey408
05-11-2007 09:38 PM
brad_prelude
01-18-2005 02:44 PM
