how much power will i gain?
Old May 6, 2003 | 08:24 PM
egboost's Avatar
Default how much power will i gain?
i will be sending out my block next week i'm trying to decide to go with stock bore or 84mm.Planning on running high boost will it even matter and if is even worth it.what is the hp figure between the 2.
thanks.
Old May 6, 2003 | 08:29 PM
egboost's Avatar
Default Re: how much power will i gain? (egboost)
bump^
Old May 6, 2003 | 08:45 PM
egboost's Avatar
a little help...
Old May 6, 2003 | 08:54 PM
PrecisionH23a's Avatar
17.34213983hp
Honestly though, i dont know off the top of my head. Which sleeves are you looking at going with? Make sure with the sleeve company that their sleeves can hold a 84mm bore. Going that big doesnt really leave you with any "extra" room to play with in case anything happens... such as melting a piston and scarring your walls. Usually when this happens you go up 10 over in bore as well as piston size, if you are running 84mm and thats the LARGEST that the sleeve company recommends then if anything happens you'll be resleeving again.
Old May 6, 2003 | 08:57 PM
egboost's Avatar
Default Re: how much power will i gain? (GudeH23a)
abes sleeves
golf-mk3
May 8, 2010 03:11 PM
crvtkllr
Nov 29, 2006 05:33 AM
asubennett
Jan 3, 2005 07:27 PM
grappler
May 5, 2004 04:56 PM
94si94cx
Apr 6, 2004 11:54 PM
