Leakdown question... Is 12% all that bad?
Old May 10, 2003 | 02:24 AM
mskibbz-T's Avatar
Default Leakdown question... Is 12% all that bad?
I have under 5% leakdown in 3 cylinders and 12% in one cylinder, this leakdown test was after a valve adjustment. Dealership said it was within spec, but that 12% looks scary. This is a bone stock b18b. Thanks
Old May 10, 2003 | 07:51 AM
XDEep's Avatar
Default Re: Leakdown question... Is 12% all that bad? (mskibbz-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mskibbz-T &raquo;</TD></TR><TR><TD CLASS="quote">I have under 5% leakdown in 3 cylinders and 12% in one cylinder, this leakdown test was after a valve adjustment. Dealership said it was within spec, but that 12% looks scary. This is a bone stock b18b. Thanks</TD></TR></TABLE>
what were your compression numbers? where is it leaking?
Old May 10, 2003 | 08:03 AM
earl's Avatar
Default Re: Leakdown question... Is 12% all that bad? (XDEep)
If the car runs smooth and still passes smog, I would not worry about it.
Old May 11, 2003 | 06:20 AM
mskibbz-T's Avatar
Default Re: Leakdown question... Is 12% all that bad? (earl)
Thanks for the replies... I did not get compression numbers. It was an incredibly shady experience at the Seattle downtown Honda dealership I overrevved and needed a valve adjustment badly, so I limped to the dealership and dropped it off to get my valves inspected and adjusted and for a leakdown and compression test. On Monday, I was called and told that I had over 75% leakdown in 3 cylinders and that I had bent valves, and my engine was beyond repair. They asked if I wanted to either swap in a 5k b18b for $4300 or a 35k b18b for $4100, I said I would have to think about it(read: leave my car there while I found an engine elsewhere ) I found an engine at Import Auto Salvage, so I went to the dealer and asked to pick my car up because I was going to get an engine somewhere else. They made me wait an hour and then told me... "we just did a valve adjustment and now your car is completely within spec, aren't you happy?" They did a leakdown test BEFORE the valve adjustment... I couldn't ******* believe it, they were just trying to get me to spend 4k on a swap... I didn't ask about the compression test they said they were going to do, I just wanted to get out of there. I am done with dealerships, they suck... This was my lengthy explanation of why I don't have compression test #s Car idles and runs smooth and I don't feel a big lack of power, so I think it is doing alright. I am hoping it lasts for about 6 months until I can afford a built block. Thanks for the replies
Old May 11, 2003 | 07:53 AM
earl's Avatar
That is a horrible story. You should write the FACTORY and tell them of your experience with that dealer. Also demand a refund of your $. Also find an independent Honda garage and quit going to dealers.
Old May 11, 2003 | 08:58 AM
93LSivic's Avatar
Yeah, thats a shitty story man. I would definetly contact Honda and dime out that dealership.
On another note. A Helms, a set of feeler gauges, a 10mm wrench, a flathead screwdriver, and a pepboys leakdown and compression tester should be on your next "need to buy" list. Its all not that hard and you shouldnt have to ever take your car to honda.
Brandon Peters
Oct 18, 2015 05:40 PM
DCiFound
Sep 7, 2014 10:43 PM
ozh_hawaiian
Jun 24, 2011 12:03 AM
89civichb
11
Mar 10, 2009 08:26 AM
SiR831
Feb 17, 2004 08:47 AM
