what rpm should i launch at ?? pls help...
i got a 89 crx w/ gsr boost 9 lbs.
i have 205/55/15 bfg drag radials..
it's gonna be my first time at the track with this set up.. anyone have any suggestions??
what tire pressure should i set my tires to? all motor i use to set it a 18lbs. but my best 60' was only 2.2.... thats sucks...
Re: what rpm should i launch at ?? pls help... (TuRbO_CrX_7o2)
i borrowed drag radials from bf Goodrich, i left at about 5500, the psi was at 15, they recommended no burnouts though i found just a couple turns helped my 60'. i was squeezing a 60 shot only also, hit in in first gear, still had a lot of tire spin but it was better than of course full street tires. i recommend just going out there and trying it as many times you can and seeing what works best for you.
crazyitr
08-03-2003 11:19 PM
