Injector question
Old May 9, 2003 | 06:06 AM
ZEXGS-R's Avatar
Default Injector question
My setup:
2000 Integra GS-R
JRSC @ 6lbs
Cartech FMU
B&M FPR
I/H/E
My question is the last time i was on the dyno i was running a little lean. 12.5 to 1. I am saving to get the AEM EMS but in the mean time can i just install a set of 310"s and lower the fuel pressure to get the mix alittle richer? Any help would be appreciated.
Old May 9, 2003 | 07:42 AM
TurbochrgedTIBBI's Avatar
12.5 to 1 actually isnt too bad. If its not detonating....The car might be getting the right amount of fuel. any more and you could richen it too much and car would bog.
Old May 9, 2003 | 08:43 AM
ZEXGS-R's Avatar
Default Re: (TurbochrgedTIBBI)
This is whats confusing me. I am running 60psi for a static fuel pressure (which i think is way to high) but when i hit boost my A/F gauge only goes to the first green light in the rich side (after i got it tuned it went all the way to the last light in rich). Seems to me with that much pressure it should be pretty rich. My FMU is also turned all the way up so that is why i thought bigger injectors would help.
Old May 19, 2003 | 10:13 PM
well considering your FMU is turned all the way up....Your stock injectors can only push so much fuel. If you want to run richer....upgraded injectors would help. But remember, too much fuel isnt the greatest either!
nfinitecc
Dec 4, 2005 02:45 PM
Green Lude 93
Sep 20, 2004 12:56 PM
bluesi00
Jun 7, 2004 09:04 PM
Hybrid
Aug 16, 2002 02:56 AM
OneScarySOHC
Jun 9, 2002 01:21 PM
