Turbo Priming
Old May 7, 2003 | 10:09 PM
FastNFurious
Guest
Posts: n/a
Default Turbo Priming
I heard that a good way to get oil flowing to your turbo for the first time before you start it up is by pulling your spark plug wires and cranking the engine like 10 times? Is this true?
Old May 7, 2003 | 10:10 PM
94dxt's Avatar
Default Re: Turbo Priming (David555)
you can pull the ignition fuse
Old May 7, 2003 | 11:48 PM
boostaholic's Avatar
Default Re: Turbo Priming (94dxt)
Pull the fuel injection fuse and the spark plugs so it's easier on the starter. Then just crank the motor over in 15 second intervals until you see oil coming out the feed line. Then connect it back to the turbo and crank it over a few more times, and you should be good to go.
velisma
May 16, 2010 08:44 AM
blakacintegra
Jun 15, 2007 04:20 AM
siblue_gzer
Oct 7, 2006 06:59 PM
jfoster
Jan 30, 2005 06:50 PM
DubyaAye
Nov 22, 2003 05:38 PM
