Help with oil feed and return lines
Old May 9, 2003 | 02:51 AM
integra-modder's Avatar
Default Help with oil feed and return lines
I have a T04E with an Inline Pro manifold that will be mounted to a b18c1.
I want to have SS lines pre made for the application because they are a lot less expensive if you get them professionally done rather than using Earls reusable adapters.
Does anyone know the exact legths of that I would need to run for each line?
Thanks
Old May 9, 2003 | 05:21 AM
mike1114's Avatar
Default Re: Help with oil feed and return lines (integra-modder)
pm or email flamenco_T aka stan. He sells lines. I got a set of lines from him, they are beautiful. Top quality, good communication, fast shipping.
Old May 9, 2003 | 07:28 AM
2000GSRT's Avatar
Default Re: Help with oil feed and return lines (mike1114)
I'd get about 4 feet for the oil feed and a foot and a half for the return. You might not use the full foot and 1/2, but you can always cut it down if you need to.
Old May 9, 2003 | 08:49 AM
Default Re: Help with oil feed and return lines (2000GSRT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000GSRT &raquo;</TD></TR><TR><TD CLASS="quote">I'd get about 4 feet for the oil feed and a foot and a half for the return. You might not use the full foot and 1/2, but you can always cut it down if you need to.</TD></TR></TABLE>
Thats the thing, I cant cut it down. I am having the fittings put on them at the shop. They are compression fittings put on with a big machine, not reusable fittings. This is why Im trying to find very precise measurements for the lines.
Old May 9, 2003 | 09:05 AM
Tinker219's Avatar
get out a piece of string, run it where you want your lines to go, cut, measure. theres your precise measurement
Old May 9, 2003 | 09:06 AM
Spudddy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra-modder &raquo;</TD></TR><TR><TD CLASS="quote">
Thats the thing, I cant cut it down. I am having the fittings put on them at the shop. They are compression fittings put on with a big machine, not reusable fittings. This is why Im trying to find very precise measurements for the lines.</TD></TR></TABLE>
Unless you know exactly where your turbo is going to sit and you know exactly where your hole in your oil pan is going to be, and then the exact size of the adapters on the end.. then you'll be able to figure out the exact length. Also depending on how far you can screw in the flanage and the nipple on the end of the flange too. you'll be close but not real exact. And for the Feed line.. well those are kinda long and thin and depending on what setup your going with.. Best advice.. just get a kit from flam or art
Old May 9, 2003 | 11:02 AM
B18EG6's Avatar
Default Re: Help with oil feed and return lines (Spudddy)
Earls makes a kit to pressure test your lines once assembled...its around 75 bucks but you can test them yourself to see how reliable they are.
The oil return has much less margin of error for the oil feed. If the feed is a half foot too long or something you can just route it a little more downward, or around something to make up for the extra length.
When I ordered premade feed line, I had 4 feet from the top of the firewall to the feed port on the turbo. I dont have a measurement of the return line but I have an accurate picture if you are interested in seeing.
Old May 9, 2003 | 01:46 PM
Flamenco-T's Avatar
Default Re: Help with oil feed and return lines (B18EG6)
Where your oil pan weld on bung located within the oil pan will differs how long your lines is actually gonna be. I replied to your IM. I came up with a solutions for you
stan
Old May 9, 2003 | 04:10 PM
Default Re: Help with oil feed and return lines (Flamenco-T)
since there is no bung in my oil pan currently, and I dont even have the turbo yet to begin to immagine where it would all line up...
I stated my previous statement incorrectly. I want to find measurement as close to exact as possbile, within an inch of its actuall length. Id rather it be a bit longer and move the oil pan bung furth over to the side than have the hose too short.
Old May 10, 2003 | 08:43 AM
Do you guys tap into the oil like at 45 degree angles or do you come straight off?
Old May 10, 2003 | 10:20 AM
B18EG6's Avatar
mine is 45 degrees off of the oil pan, and 45 degrees off of the turbo
Old May 10, 2003 | 05:24 PM
GOLDBERG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra-modder &raquo;</TD></TR><TR><TD CLASS="quote">Do you guys tap into the oil like at 45 degree angles or do you come straight off?</TD></TR></TABLE>
you talking about feed or return??for the feed it dont matter..whatever fits yo..line is pressurized...for the return you are going to want a sloped angle down def
Old May 11, 2003 | 01:29 PM
yea, I found the parts needed to get it from earls and the 45 degree connectors for the return line are like 30 bucks a piece....are there any fittings that are the regular cost of like 5-10 bucks?
Old May 11, 2003 | 06:18 PM
B18EG6's Avatar
I dunno, you might be able to find prefabbed pieces that dont use Army Navy fittings... but i just bit the bullet and coughed up 50 bucks for two stupid fittings
Old May 11, 2003 | 09:23 PM
Flamenco-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18EG6 &raquo;</TD></TR><TR><TD CLASS="quote">coughed up 50 bucks for two stupid fittings</TD></TR></TABLE>
should've IM'ed me hehehe
Old May 12, 2003 | 02:40 AM
I think if you really want to ghetto rig it you can probably goto home depot or lowes and get a **** load of brass connectors and fittings and do the same thing. I mean they do use SS lines for like toilets, dishwashing, and clothes washing machines...
Anyone know the amount of pipe that you'd need if you wanted to mount the T on the firewall from the supply line?
hondaeg8
May 23, 2006 11:53 AM
shrug
Nov 4, 2004 06:21 PM
drosen55
Mar 2, 2004 06:43 PM
importboi22
Oct 15, 2003 07:46 PM
BlackGSR
Apr 7, 2002 06:11 PM
