for the pros
Old May 9, 2003 | 05:50 PM
APEX i GSR's Avatar
Default for the pros
well i have a question for Art,Vapor Trail & the rest (can't think right now)
here is what happened and what has put my boost project on hold:
DO NOT get the 6 puck clutch
i had one ACT unsprung clutch with a brand new ITR transmission
after 2 years of driving around with a on & off switch chirping 1st, 2nd,3rd & 4th gears it broke yesterday with no warning
the differential shattered & took the mainshaft & input shaft with it
i dunno how many gears it took with it
so now i have to get a new trans (probably another ITR) and this time i will run a regular spung hub ACT clutch
this is just a warning to those thinking of getting a 6 puck clutch
i was in the middle of a turbo project which will now be put on hold or the parts sold so i can put the car back on the road
i can get another ITR tranny (just found out while typing this post)
for a really good deal
will this be optimum or will it hold me back from reaching 350whp tuned?
Old May 9, 2003 | 05:52 PM
APEX i GSR's Avatar
Default Re: for the pros (APEX i GSR)
i also had a Toda flywheel
which i will be getting rid of
Old May 10, 2003 | 06:26 AM
APEX i GSR's Avatar
ttt
Old May 10, 2003 | 06:31 AM
boosted3g's Avatar
sucks about your tranny but on a positive note i would be interested in your flywheel if its not bitched up.
Old May 10, 2003 | 07:20 AM
APEX i GSR's Avatar
Default Re: for the pros (boosted3g)
i have no idea of the condition of it
i was told that it could not be machined but if you want it hit me up
i'll be taking it out when i finally get the tranny
thinking about going with a Fidanza
Old May 10, 2003 | 07:41 AM
VaporTrail's Avatar
New User
I definately don't recommend unsprung clutches for the street. Unfortunately, you found out why. That shock is a lot of abuse to the drive train, and under repeated stress, things break, no matter what its made of.
Have you thought about getting a B16 or GSR trans instead of the ITR, and putting the money saved into a Quaife? Thats what I would do. However, if you stick with the ITR, it's not going to hinder you. Another option might be to get a new/used casing, and fix the trans you have now.
Best of luck.
Old May 10, 2003 | 07:57 AM
APEX i GSR's Avatar
Default Re: for the pros (VaporTrail)
thanks for the help John
i actually sold the busted tranny and i'm getting an extremely great deal on a new ITR tranny
the guy thats buying it is going to rebuild it
do you have any clutch recommendations for about a max of 380 whp
i was thinking ACT with a Fidanza or ACT flywheel
Old May 10, 2003 | 05:54 PM
APEX i GSR's Avatar
to the top
Old May 10, 2003 | 06:07 PM
VaporTrail's Avatar
New User
act clutch is a great choice
their flywheels are excellent as well
Old May 10, 2003 | 06:32 PM
LSiTurbo's Avatar
i have had teh same ACT Extreme clutch with unsprung 6-puck for 3 years now and have had no problems, it has been boosted for 2 1/2 of those years also. They are strong, and have never given me any problems. Sorry to here about yours though.
Old May 10, 2003 | 06:36 PM
APEX i GSR's Avatar
Default Re: for the pros (LSiTurbo)
i had the standard pressure plate not the extreme
Old May 11, 2003 | 09:02 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
6 puck is fine.
The problem was you got a unsprung hub .
If its sprung the engagement isn't as harsh.
Old May 11, 2003 | 06:54 PM
APEX i GSR's Avatar
Default Re: for the pros (Apex i ITR)
yeah yeah yeah i know <U>NOW</U>
but i will be getting a sensible clutch this time
Old May 11, 2003 | 07:15 PM
DaveF's Avatar
the same thing happend to my friend's 2001 type r only after a year or so(maybe 10 months) of boosting, took out the diff and every gear..sorry to hear bout your car, hope u can get it up and runnning soon. good luck
if anyone knows about gear ratios(i sure as hell dont) would a gsr trans with 4.9 fd be ok to run with 28 inch slicks???? what rpm would i be looking at in the traps in 4th gear(shooting for 160mph+) i was gonna go b16 but i got this mint jdm gsr trans sitting here, looking all pretty
Old May 12, 2003 | 08:34 AM
APEX i GSR's Avatar
any body else have any suggestions
Old May 12, 2003 | 08:41 AM
dfoxengr's Avatar
i know a guy who hit 475 whp on stock jdm ITR trans and CM stage 4 clutch
should be fine
Old May 12, 2003 | 08:45 AM
PM-Performance's Avatar
i coulda told you that too , we learned the hard way a few years ago too .
they just dont react well to daily driving .
i have the XTSS in my R now it it holds great im on my 3rd season with it and it has taken a beating . they arerated upto 320ft lbs of tq, so im sure youll be cool with it for a while.
it snot the hp that kills thme , its the TQ
UnionCity LS
Apr 10, 2003 06:09 PM
nuport
Nov 14, 2002 11:45 PM
GQ 05YellowEVO8
Aug 22, 2002 02:29 PM
COREY ITR#625
Dec 26, 2001 07:43 AM
1fastGSR
Dec 3, 2001 05:57 PM
