max rev and 60-1
Old May 6, 2003 | 08:55 PM
B16 BROTHER's Avatar
Default max rev and 60-1
I have been searching but have found no results i have a b series motor with a max rev manifold and my block is currently being sleeved. My question is what turbo should I use on a built b16 to achive 350 horse. I was told t3 60-1 but was curious would it fit.
Old May 6, 2003 | 09:04 PM
Gravy's Avatar
Default Re: max rev and 60-1 (B16 BROTHER)
i can help you out with a precision turbo that will get the numbers that you want.
Old May 6, 2003 | 09:40 PM
LJR-LUDE01's Avatar
this is my T3/T60-1 with the max-rev manifold, not sure how much space you got but I couldn't clock the compressor housing to be straight up so I had to run my piping through the bottom and it was a pain in the ***.
edit: forgot to add that this is on a H22
Old May 6, 2003 | 10:14 PM
Full-Race Javier's Avatar
u can achieve 350 with a t3/t04e. a t3 60-1 does fit with a maxrev mani. u will probably have a wider power band and better response on the 1.6L with the smaller turbo though....depends on what ur looking for
here are some pics on a b-series (not my car)
Old May 6, 2003 | 10:27 PM
JDM_SiR_II_EG's Avatar
Default Re: max rev and 60-1 (javierb14)
javier is right...he knows everything and is smart guy....listen to javier, he has *****....
this is jason btw
Old May 6, 2003 | 10:35 PM
Default Re: max rev and 60-1 (JDM_SiR_II_EG)
haha....
Boostinb20!
Mar 4, 2009 06:45 PM
skUnK2jdm
Nov 30, 2007 05:20 PM
mengy007
Apr 4, 2007 09:57 AM
wrx'n you
Nov 24, 2006 05:26 PM
StolenTeg
May 28, 2004 09:58 PM
