polishing my parts....
i want to polish my intercooler endtanks, my manifold, and my turbo housing, but the problem is.. i dont know CRAP about polishing.. i sanded my manifold down (maxrev) and it looks pretty nice, its ready to polish, but i gotta send it back to maxrev cuz the threading was fuked up.. anyhow... someone wanna hook it up on a polish job for cheap?, i dont really have the time these days, but it would be great if someone here does good polishing.. can pay ya.. im in so cali
Re: polishing my parts.... (JDEM1)
just get some metal polish from an autoparts store...less than $10...metal polish and elbo grease is all you need
Re: polishing my parts.... (MiraiZ)
hm, what if there are scuffs on the intercooler endtanks.. how do i go about getting those out... its semi polished but scuffed a bit, dont know why.. but it looks like i cant sand it down like i can do to my manifold.. hm...
Well to the best of my knowledge, polishing takes LOTS of time... all you need to do is keep sanding it down with a higher grit #.. all the way to like 2000 grit. Then buy some polishing compound and rub it out.. Very long process. Find jonnnydanger on this board, he prolly wont have time to do it but he can give you tips on how to do it!! GOod luck!
Re: polishing my parts.... (arsenaldragster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arsenaldragster »</TD></TR><TR><TD CLASS="quote">p.s. polishing the endtanks should take out the scuffs!</TD></TR></TABLE>
thanks for the tips, anyone else?
polishing scuffs makes shiny scuffs... it will look better, but it will still be obvious.. if you are going to spend the time polishing, then do it right.. it only takes a little longer
like was already mentioned, you sand with higher and higher sandpaper untill the surface is perfectly smooth and shiny...
then put a little polishing compound on a polishing wheel on a grinder and polish away..
for extra shiny surface you can use multiple stage polishing wheels.. they have a had one to start out, then medium, then soft... use a jewlers rouge with the soft wheel and your parts will shine like chrome
Re: polishing my parts.... (Suprdave)
This is me in the reflection on what the maxrev did to my hands after hand polishing it. ---It wasnt worth the time.
Re: polishing my parts.... (93LSivic)
hand polishing omg..
dood just get an angle grinder with a 5" spiral sewn disc. after liek 600 grit itll polish right up..
good luck.
good luck.
Re: polishing my parts.... (shortyz)
i do half *** jobs....they look better than before and take like one or two hours depending on what i did....but basically you need to sand a lot....which i dont cuz i have better things to do, and people usually dont look at my polished **** close enough to see it needs more sanding
Re: (hulkhb)
wow i wish i took the time to polish all my stuff, it just looks really nice over the crappy discolored manifold and stuff that i have. oh well, it all works the same eh?
did someone say bling bling...hahahaha:
http://home.sport.rr.com/spazt...0.jpg
Polished intercooler:
http://home.sport.rr.com/spazt...7.jpg
