Steps to Removing Turbo, Manifold, and Downpipe???
I was wondering if someone could tell me the easiest way to take off the Turbo, Mani, and downpipe on a 99 Civic Si w/ a b16. I had a shop do it, and have and idea of how to take it off, but just wondered if anyone had any tips? And by the way I am replacing all the parts when I give Arturbo a call.....
Re: Steps to Removing Turbo, Manifold, and Downpipe??? (civicqm)
what kind of kit you have?
start with the DP. the turbo and manifold can come off together.
un bolt all the bolts
It's pretty self explanitory, but heres a little more detail
-Unbolt downpipe from Turbo
-Take off Oil Feed and Return Lines
-Unbolt Turbo From Manifold
-Unbolt Manifold from Head
1) take off oil lines
2)take off pipe connecting turbo to ic
3)unbolt downpipe from turbo
4)unbolt manifold and pull off from head
5) cover oil return hole on pan
6)drain oil
7) remove oil filter
8)remove oil feed line and fittings from block
9)put back oil pressure sensor in block
10) put back stock parts, such as headers, etc
6)drain oil
ITRfaithful
08-10-2002 12:59 PM
My manifold to turbo bolts are loose....any way to tighten up without removing the whole manifold an
Flamenco-T
10-30-2001 03:48 PM
