2mm head gasket?
Old May 7, 2003 | 03:12 PM
ZERO COOL's Avatar
New User
Default 2mm head gasket?
I wont be running over 12 lbs of boost, but my setup is a stock 1 gen b16a and I am keeping the internals stock. What is a good size head gasket to go with? What company is good? Could some people post websites as well.
Old May 7, 2003 | 03:18 PM
dfoxengr's Avatar
Default Re: 2mm head gasket? (ZERO COOL)
http://www.inlinepro.com call them too
Old May 9, 2003 | 09:44 AM
ZERO COOL's Avatar
New User
Default Re: 2mm head gasket? (hybridvteceg)
Any other websites? Is 2mm a good size or should I go with something else?
Old May 9, 2003 | 11:02 AM
turbochic's Avatar
got my gasket from inline pro, a 2mm. you could also contact cometic.
http://www.cometic.com the inline pro gaket is a high quality gasket. i was pretty impressed with mine
Old May 9, 2003 | 11:49 AM
jinxproof99's Avatar
New User
2 or 3mm depending on your goals/set up/gas.
Old May 9, 2003 | 12:29 PM
intekragsr's Avatar
Default Re: 2mm head gasket? (jinxproof99)
Dont forget you need adjustable cam gears with 2mm and above. The extra height of the head will throw off the cam timing.
Old May 9, 2003 | 01:00 PM
dfoxengr's Avatar
3 may be too much. stick with 2. i think it lowers say from 12:1 comp. to 11:1
dfoxengr's Avatar
but if using a stock motor, i would get an Inline Pro stock height gasket...
Old May 9, 2003 | 01:02 PM
turbochic's Avatar
actually on a b16a it would lower it to 8.9:1, stock is 10.2:1, yeah you definately need cam gears, and 3mm would be way too much.
ALso I would not do stock head gasket, it leaves too much of a margin for error. unless you have a stand alone where you can tune according to your stock comp ratio.
jdm ek9 101
Sep 12, 2006 07:00 AM
gsrious
Feb 5, 2006 09:22 AM
bitchin camaro
Jan 22, 2005 01:29 PM
copper
Feb 1, 2004 09:51 PM
