Turbo
Old May 7, 2003 | 11:39 PM
99turbosi's Avatar
Default Turbo
Anyone have any suggestions why my turbo is only pushing 5lbs of boost and there is a 9lb spring in my wastegate? The autometer gauge I am using is only reading 5 lbs a full throttle in 3rd gear and I know that the autometer gauges are not the most accuarate but my car just isnt pulling the way is should be ... it dyno 163 to the wheels that is horrible for a 99 civic si with t3/t4 turbo ... any idea why I am making such shitty power and have no pull in the car?
Old May 7, 2003 | 11:55 PM
Stu's Avatar
Stu
New User
Default Re: Turbo (99turbosi)
If you have really restricted exhaust it will do that.
Old May 8, 2003 | 06:06 AM
13lude's Avatar
You might want to check for leaks. I had a small leak and was only able to boost like 3psi when I had the boost controller set at 7psi
Old May 8, 2003 | 07:24 AM
boosted_dc2's Avatar
Default Re: Turbo (13lude)
check for loose couplers on your charge piping.
1sic3dr
Aug 11, 2007 03:28 PM
99blackdc2
Mar 21, 2007 06:38 AM
RFd15bhatch
May 24, 2005 12:27 PM
apexrift
Mar 1, 2005 12:59 PM
miketurbohonda
Jan 4, 2004 08:32 PM
